Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The mowing deck on craftmans lt200 is leaning to one side. this causes an uneven cut
  • Craftsman Master
  • 8,404 Answers
I think one of the hangers has become disconnected. There should be a leveling procedure for this in your owners manual. If you dont have that manual ... you may find the leveling procedure at the Sears web site. Leveling procedure is pretty standard ... the basic idea is get on a level surface --- your garage --- measure from the deck to the floor on 4 corners ... make adjustments as required front to back and then side to side. Once you are on the floor ... you will see what to do.
Posted on May 15, 2010
  • A Miller May 15, 2010
    Thanks for your interest in FixYa.com
Masport series 20 mowing uneven
check /replace blades
level up the mower deck
the blades have to be parallel to the ground so if wheels are worn or the deck tilts in any direction the cut will be uneven
Feb 03, 2017 | Garden
I have a problem leveling my mower deck. I level it at the sides and front .I use the mower and it cuts uneven. mower is deck is out of alignment. less than 1 hour on it.
The deck could be bent, or you will probably have to level the back of the deck as well. Another thing to check is the air in the tires, this can cause an uneven cut. Although the tire may look pumped up, with the weight of a person on the tractor can cause an uneven cut.
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman Zeroturn deck mows unevenly??
u should get on flat surface an loosen guides bolts let it drop all the way down then tighten ur guide bolds an that should solve problem u can make sure none of ur pins are wore but they can usually ware almost all the way through and still not make it cut bad now before u adjust the deck check blade they have been known to cut bad if wore or bent
Mar 27, 2017 | Craftsman 21 HP 42 in. Zero Turn Tractor...
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
42" deck - uneven mowing in the center
yes its repairable & yes it can bend the spendle but most likely the blades is it one that does it or both blades or the center or the sides of deck is bent by stepping on the deck let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
370 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
