Question about Fisher and Paykel GWL11 Top Load Washer
AGATOR HAS BROKEN FINS
How do I replace the agator?
  • 343 Answers
Take the cone out of the top of the agitator and you will see a large plastic wing nut down inside the agitator tube. Undo wing nut and agitator should lift of the splined shaft.. It may be a little tight.. Gently wriggle top to loosen. Make sure you get the same size to replace it, as there are different sizes....Good luck....Nomess
Posted on May 16, 2010
The agitator doesn't spin
probably a problem wash engage solenoid underneath or broken drive belt
call an technician in for a proper diagnosis and a quote
Jul 15, 2016 | Whirlpool Ultimate Care II LSQ9549L Top...
Agator doesn't work
Is this a whirlpool washer? The agitator dogs need to be replaced. Remove top cap on agitator, then plastic cover inside it, then remove bolt, then pull agitator off. Top can separate from bottom by standing on bottom and pulling up on upper. Go to Repairclinic.com to find agitator dogs.
Nov 19, 2011 | Whirlpool Washing Machines
Washer,is making a metallic clank sound when agatating,any ideas.
could be the transmission going out or something as simply as a broken damper strap. with the washer turned OFF open the lid and check for extreme side to side or front to back movement of the outer tub. if there is then you need to order replacement dampener straps or mounting straps. its late here and I don't remember exactly what they are called LOL
Jan 23, 2010 | Kenmore 22942 Top Load Washer
Maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Jun 01, 2009 | Maytag Legacy Series Top Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Top half of agatator don't turn
Remove the agitator. Place it on the floor. Put your feet on the base and yank the top portion off. Replace these:
124bfd8.jpgPart number 80040 agit dogs(4)
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Wont fill and agatate
sounds like the water valve check for supply taps make sure there on test solenoid's on valve for ohms Resistance or closed circuitif open replace water valve
Aug 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Fisher and Paykel GWL11 Top Load Washer Logo
171 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
