Question about Microsoft Windows XP Home Edition
Getting a No sync message on monitor ,computer
Getting a No sync message on monitor ,computer will no turn on ...can any one help .I have windows Xp
    Novelist:
  • 106 Answers
No sync message could be for 2 reasons.
1. Loose VGA cable
2. Wrong driver installed or configuration made is out of monitor range
For loose cable you can fix it up from both ends, on CPU and on Monitor itself.
For second reason, we just have to delete display driver from Device Manager. Follow below method to delete driver
Start computer in safe mode. To start in safe mode, as soon the system boots up press F8 and select Safe Mode. After you log into the safe mode. Right click the "My Computer" icon on desktop, go to properties,
go to "Hardware" tab, Click on "Device Manager", go to "Display driver" and expland it, select the driver below the expanded "Display Driver" and press delete to remove the driver. Now restart the system and it will automatically adjust the display driver for you.
Posted on May 15, 2010
I have LCD monitor screen & windows xp as operating system.i cannot remove auto adjusting message box. it flashes on screen after every 2-3 seconds & due to this my screen will auto adjust at every...
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
Mar 20, 2011 | BenQ FP71G+ 17" LCD Monitor
I set my computer to power save mode last night by changing the setting so the monitor would turn off after 5 hours. Now I can't get it to come back on. I've tried moving the mouse, turning the monitor...
hold the power button down for 5 secounds, then turn back on . if you can get the bios load up page try pressing f12 or f8 constantly untill u get a menu to boot computer in safe mode and try tunring this power saving off and restart.
Nov 29, 2009 | Sony VAIO Digital Studio PCV-RZ24G PC...
Just installed new dell 23 inch widescreen monitor with cam and it turns off ('no connection to computer" message) just before xp sp3 desktop load, works fine with windows 7.
drivers for xp sp3 may not be compatible with w7 drivers.
running dual partitions? xp/w7? could be drivers are not getting along! sounds like microsoft to me!!
good luck
Oct 18, 2009 | Computers & Internet
Won't let me sync anymore
What i would recommend you to do is if you have windows xp to uninstall windows media player 11 and reinstall windows media player...if you already have 10 just upgrade to 11..
That should solve the problem
I hope that helps
Thank you
Mar 05, 2009 | SanDisk Sansa Fuze MP3 Player
Sync out Of range
You need to get the monitor back into a range it can use and the best way is to go into SAFE mode on the pc put it back into 640X 480 and at 60 hz refresh rate. 37.9khz is way too high for the monitor!
It is best in the 60hz to 80 hz (if it can go that high!) start at 60 to begin with and it will work.
Good Luck!
Rich Lilja
Nov 24, 2008 | Samtron MONO TTL 13 Monitor
SCREEN READS NTLDR IS MISSING
Hi TAPOLA,
If you are getting this message, then rhe problem is not with your monitor at all. It is actually with your Windows XP operating system. Your monitor is working fine. Though to fix the problem you would need to get your Windows XP CD and boot off the disc, if you boot from the CD you will get a brief message "Press any key to boot from CD..." as soon as you see that you need to press any key within 5 seconds. If done successfully you'll see a different screen and its a blue screen with loading files on it. Afterwards it will be on the setup page so press "R" for recovery console and on the command prompt you need to type this command: CHKDSK /R and it will run scan and repair of Windows.It will take sometime, afterwards it will bring you on the prompt and you just need to type EXIT to reboot the system. Just let it reboot to Windows and see if it works.
Hope his helps!
Peace! :)
Oct 22, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
The HP monitor stop working with systemax windows xp
no vga input message means that the monitor is working fine, and the problem is probably your pc. check the cable connecting the monitor to the pc. if that is ok, you ma have to open up the pc and check some components, most likely the RAM
May 02, 2008 | Microsoft Windows XP Home Edition
Problems with installing Active Sync on Windows xp.
Do you use companion CD for Active sync installation? Can you please tell me which driver is necessary to have? Is there any error message and what is content of this message? It can also be that Active Sync is already installed! Please check at Add and remove Software in Control panel! Otherwise go to www.microsoft.com and download a current version of active sync
Sep 11, 2005 | Toshiba e400 Pocket PC
Microsoft Windows XP Home Edition Logo
303 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
