Question about Video Cameras
Jammed tape in Sony camcorder
The cassette jammed in my camcorder and though i hear the camera attempt an eject it seems like it is jammed and it does not come out.
is there a release button to manually eject the cassette?
  • 1 more comment
  • dm08 May 24, 2008
    I am having the same problem, and it seems that there must be a manual eject somewhere, but I haven't found it.
    Can anybody help, please?
    Or, is it possible to buy just a player? I only need to play the tapes once more to copy to DVD.
  • Anonymous Dec 17, 2008
    NOW IM ALSO HAVING THIS PROBLEM
    I CAN SEE THAT WHEN YOU RESET IT IT'LL EJECT AND THE TAPE WILL RISE BUT IT WILL NOT OPEN.IM GOING TO FLORIDA (DISNEY) THIS WEEKEND AND I WANT TO BE ABLE TO RECORD MY LITTLE BROTHERS' PRICELESS MOMENTS ON HIS FIRST TRIP TO DISNEY.
    IS THERE A WAY I CAN SOLVE THIS PROBLEM?
  • pacosant Jan 17, 2009
    Cassette is jammed and does not come out, is there a manual way to eject it?
  • 3 Answers
There is no manual eject.
The only way is to disassemble the camera outer shell, then remove the drive mechanism and using a 4.5 V power supply power the eject mechanism.
It takes 30 min of work when you know how to do it. If you find the service manual (free somewhere in internet) it will tell you how to open the camera.
Hope this helps.
DocG4
Posted on Dec 24, 2008
  • rolandtan55 Nov 29, 2010
    this may be a few years too late but i solved the same problem by first switching the camcorder off, removing the battery, switch the camcorder to camera for 15 seconds, replacing the battery and switching the camcorder on again. Hope this works for any one else.
Sony handycam ccd-trv59e C32 10
The camera's firmware has sensed a jam or too slow rotation in the cassette's take-up roller. Really difficult to overcome. The tape may already be snarled round a roller, but is certainly in the "loaded" tape path. I've had this and had to disassemble the whole tape transport mechanism - which is really difficult - after trying unsuccessfully to drive the unload motor from an external 6v power supply. Sometimes a really hard sideways bang on the camera can free up the roller enough to let it rotate a bit, satisfy the motion sensor and allow an eject.
Jul 07, 2014 | Sony Handycam DCR-TRV520 Digital Camcorder
Tape will not load; Error code 31:23
You may try the following troubleshooting steps:
Remove the battery of the Camcorder for one minute and re-insert the battery to check whether it works.
You may try resetting the Camcorder by pressing the RESET button located on it.
You may also check whether the issue occurs for all the tapes.
If the issue occurs with all the Tapes then it seems that internal parts of the Camcorder are malfunctioning.
Hence, the Camcorder requires service.
Jul 14, 2010 | Sony Handycam DCR-PC1000 Mini DV Digital...
Sony trv25 cassette does not eject
These can have ls chassis failure causing the tapes to jam in the set. Can be repaired under $200 in most cases. Larry's Electronics 916-362-8708 ledstiles@hotmail.com
Apr 22, 2010 | Sony Handycam DCR-TRV25 Mini DV Digital...
It wont eject or play makes lound noise for a min
There is a broken plastic part on the cassette. Needs to be replaced.
Mostly caused by improper position of the tape and camera jam(tape jam)
needs sony camera technician who can replace the part inside the cassette.
Apr 03, 2010 | Sony Handycam DCR-TRV310 Digital Camcorder
Hi8 won't eject cassette
There is a broken plastic part inside the cassette and needs to be replaced. Mostly due to cassette tape improper position and camera jam (tape jam).
Apr 03, 2010 | Sony Hi8 CCD-TRV138 Camcorder
Camcorder continues to show"REMOVE CASSETTE" notice
You are not alone. This is a known service problem for this series of cameras. Cannon has a service notice on its website. Look here:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=227&modelid=9037
Sep 23, 2009 | Canon Elura 40MC Mini DV Digital Camcorder
Manual eject option for trv320? No tape in it. Won't open so I can put one in.
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 06, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Video Cameras Logo
1,293 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
