Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore Front Load Washing machine and I am getting an error message f-35. what does that mean? It is an HE 3T Steam. Once I get this error code, the unit stops and unlocks.
    Guru:
  • 351 Answers
This washer seems to have multiple solutions for the f35 error,
Unplug the machine for an hour to reset the computer
Clean the filter The panel below the door has 3 screws (mine was a star shaped screw). The white cap screws off. yopu may have to cancell the error using "stop".
Please Vote !!
Posted on May 15, 2010
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
Kenmore Elite HE 3t steam washing machine shows a code of F71
The F71 error code means "User interface heartbeat failure" to put that in simple terms what it means is,the touchpad/cycle selector is not talking to the main control board. To check to see why that code is being displayed ya would need to make sure that all the wire plugs between the selector and the control board are tight and in fully pressed in and making good contact at the respective connection point on the circuit board.
If ya find the wire connections to be good and tight,ya would need to start the washer and if the drum rotates the cycle selector would have to be replaced. If the drum does not rotate the main control board would need to be replaced. oldtech2332_146.jpg
Oct 20, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE 3t washer model 11046742700 error F35 keeps comming up it just sits there.
Hi
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Aug 15, 2010 | Kenmore Elite 45986 Front Load Washer
What do you do if you get an F21 code on a Kenmore Elite HE 3t steam front load washer
The F21 error code is an indication that the unit has a too long of a drain out condition. If the control call for the unit to drain & the water does not drain out in 8 minutes or less the unit will stop & flash the F21 error code. I would recommend checking the drain pump & pressure switch circuit.
Mar 06, 2010 | Washing Machines
I am searching for a front load kitchen aid washer and cant seem to find any... did they stop making them?
Whirlpool is now making their own Duet models and the Maytag front load machines and the Kenmore He2 2t and 3t and 3t steam and the 5 with steam washers.
KitchenAid is high end Whirlpool. Haven't seen them around lately but they just might be harder to find.
Sep 10, 2009 | KitchenAid KHWS01PWH Global Horizontal...
He 3t error code f6,washer will not spin,door will not open
"f6" error code means that there a miss communication between mcu(motor speed control board) and ccu(central control unit). i recommend you to ohm out the motor. most likely its your motor speed control located at the bottom left of the washer good luck. replace the motor speed control board and you should be all set to go.
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error code 32 on a brand new Kenmore HE 3T wash machine
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
When washing, it stops and says F11. What does that mean?
F-11=Serial Communication Error
Communication between the Central Control Unit( CCU)and the MotorC ontroUl nit
(MCU) cannot be sent correctly.
PotentialCauses
. CheckW ireH arnessc onnectiontso the MCU.t he motor,a ndC entraCl ontrol
Unit (CCU)
. Checkt he Drives ysteml or anyw orno r failedc omponents
. ReplaceM CU
. ReplaceC CU
. Replace Motor
. ReplaceW ireH arnes
Apr 05, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
161 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
