Question about Alesis iO 26 Sound Card
Pops Clicks ...now worse and disconnected due to this
    Top Expert:
  • 75,822 Answers
This noise is due to a shorted component in the card, most likely an output transistor
Posted on May 15, 2010
Surha AKG uhf ht 40 handheld mic
You need a pop filter while recording. There are different reasons why a "pop" would get recorded in the signal. Either because of the harsh P's and T's while singing or rapping like "Business", "Pain", "Property", etc. or it could be jitter problem due to an unstable clock. Mostly you would recognize these ones cause they don't sound like the pops coming out o a persons mouth. They're more like clicks. Your problem, from what I understand is due to the former reason. That's why you will need a pop filter.
Jul 06, 2014 | AKG Audio Players & Recorders
The monitor screen flashes on and off. It gets worse after being on for a while. A box pops up saying no signal.
Usually due to a faulty connection between the computer and the monitor.
  • Remove the wire that connects the computer to the monitor
  • Look at the pins on both ends.
  • If there's any bent, change the wire.
Sep 16, 2011 | HP w1907 LCD Monitor
When i playback in WDM mode, i hear ckrackles and pops, when i playback in the other mode the ckrackles and pops are gon, but the input and output goes to none. how do i get rid of the ckrackles and pops...
1. check your user manual for clicks/pops.
this could be due to devices connected to the Edirol UA-25 or a television or microwave.
2. this also could be due to the setting in Windows Energy saving settings.
that is the Windows "sleep mode" and power saving mode.
3. this could also be due to the USB cable.
4. you may need an external filter device for the process you are using.
5. read your manual on Troubleshooting Noise ( clicks and pops).
Jun 14, 2011 | Edirol UA-25 External Sound System
Doors locked so broke into car. Now car will not start. Do not have key to open the doors with only the key to start the car with. Because we broke in the alarm system was going off. We disconnected the...
It should be the same key for both and if u unlock the trunk with key the alarm should turn off so you can start . had the same problem . worse comes to worse have a key made at dealership or a portable locksmith come to you. about 80 for a key. You dont wanna mess with the anti theft or wires unless u really know what your doing
Mar 29, 2011 | 1996 Nissan Maxima
Car doesnt want to start. all lights come on when in the on position however when I turn it to start nothing happens it dont even try to turn over it just clicks 2002 hyundai xg350
The starting system consists of:
  • starter motor
  • starter switch, part of the ignition switch
  • starter motor solenoid relay switch
  • starter solenoid
  • starter drive
When you turn your key to start your engine, it just clicks, right? If so, more than likely this is due to a bad battery. Even though your battery may appear to be fully charged, it may have a dead cell, or worse. If you get a jump, does the vehicle start? If so, replace your battery.
Possible sources of the problem if the engine does not crank or the relay clicks:
  1. Battery
  2. Starter motor
  3. Starter motor relay
  4. Ignition switch
  5. Damaged fuse
  6. Anti-theft system
  7. Circuitry
Mar 16, 2011 | Hyundai XG350 Cars & Trucks
1989 Nissan Pathfinder Clicks but won't start.
It sounds like a bad connection somewhere, due to a loose or corroded connection. This would explain it gradually getting worse. Check your battery cable connections. Make sure they are clean and tight. Also connections at starter. So, check those connections, let me know what you find. If that isn't it, I'll try to help further.
Mar 24, 2010 | 1989 Nissan Pathfinder
The heater in back works and so didfront but now it pops but clicks andonly blows out cold air like the front air duct is not opening up
Actuator Removal
  1. Remove the audio unit. For additional information, refer to Section 415-01 .
  1. Remove the LH instrument panel insulator. For additional information, refer to Section 501-12 .
  1. Remove the electronic actuator.
    1. Disconnect the connector.
    1. Remove the screws.
    1. Pull down to release the actuator shaft and remove the actuator.
Dec 22, 2009 | 2001 Ford Windstar
I have a 95 jeep grand cherokee limited 5.2 l. that will notstart
i had electrical problems on my cherokee before u start getting in to deep disconnect your battery for 1min then reconnect maybe computer at fault but doing this will reboot it
Nov 14, 2008 | 1996 Jeep Grand Cherokee
Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Apr 04, 2008 | Audio Players & Recorders
Alesis iO 26 Sound Card Logo
255 people viewed this question
Top Alesis Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Lawrence Oravetz
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
