Question about Whirlpool 19.6 cu. ft. Upright Freezer EV200FXM
Upper portion of freezer where the control is it is freezing up
This looks likr icey snow
  • Whirlpool Master
  • 3,247 Answers
Is it please possible to describe the problem with your Whirlpool freezer a bit clearly.
I am guessing that you are getting some sort of icey snow in the top portion of the upright freezer.
without knowing how old the freezer is or how long you have been having the ice problem, it is hard to provide a proper solution.
My guess is that air is leaking into the freezer and the snow is being formed by the moisture in the air. You may have to clean the door gasket or replace it if the seal is not proper.
Posted on May 15, 2010
  • mikeskingqua May 15, 2010
    the freezer is 1 yr old . i noticed ther is ice on the gaskets, do i have to defrost freezer or could i just clean the gaskets.
  • Sam May 16, 2010
    Ice on gasket can be cleaned but the problem is you have leaky gasket. This is reducing the performance of the freezer.
    If it is about 1 year old you should contact the Whirlpool guys and explain the situation. Could be covered under warranty. Otherwise try to rub some vaseline (not grease) around the edge of the freezer door and see if it makes a difference to the ice collection.
    Good luck.
How do I start my 13-986-144A isotemp plus, I have no manual and I don't know how to access the control menu... help...
The first thing that you should do is plug the AC cord of the freezer and open the upper portion on top of the two doors and insert the key on the slot and turn it on. Open the freezer door and locate the temperature adjustment panel inside and adjust it to your desired temperature.
Nov 17, 2010 | Fisher Scientific Freezer Isotemp* Plus...
Freezer does not freez food at all. the compressor motor run but no cool air or freez! Please advise any solution
Since you say the compressor is running, you should check the evaporator coil inside the cabinet. Remove the back wall screws, and the back wall, to expose the evaporator. If its fully encased in frost, like a square block of snow, you have a defrost problem, heater, t- stat or defrost control. If frost only at the top, your fan is not running. If its bare of frost, all you see is the aluminum coil, you have a sealed system leak of refrigeratnt
Oct 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Woods freezer yellow light looks light a snow flake wondering what that means
Does it sound like it is never shutting off/ It may mean it is over freezing. Also for good measure >>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 01, 2010 | Woods 4.3 cu. ft. / 122 liter Chest...
Went into Kenmore Upright Freezer today to discover not running and some food already soft. I unplugged plug for 1 hour and plugged back in and the unit started and has been working for last 5 hours. What...
Defrost timer/control may be defective, compressor start device may be defective, or, if this unit has the digital display on front upper portion of door, then it is bad. Give us a model number so we can look at the unit you have. What ever the prob is/was, keep close eye on unit for the next few weeks, if it is one of the above mention problems it will occur again.
Oct 01, 2009 | Freezers
Freezer icing and causing water at the same time
fault is probably the door seal. to check seal, use a slip of paper trapped between door seal and cabinet
Sep 14, 2008 | Freezers
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Apr 22, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezer freezing up
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Sep 16, 2007 | Freezers
Whirlpool 19.6 cu. ft. Upright Freezer EV200FXM Logo
70 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
