Question about Bulova Watch
Rockland rk4103 instructions
Rockland rk4103 watch alarm goes off every 5 minutes its driving me crazy. please help
marinos
  • 114 Answers
SOURCE: CASIO G-SHOCK 200 (G-7500)
The first thing I have to recommend it to unscrew it and remove the battery for a few minutes and then insert it back.
If this has solved your problem please rate this solution as "Solved" otherwise please ask us here again for more possible solutions.
Thank you :)
Posted on Oct 12, 2007
SOURCE: I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
 A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
Posted on Sep 09, 2009
  • 12 Answers
SOURCE: casio edifice mens watch user instructions needed
Go in alarm mode by pressing the mode button once twice...depending on the modes you have and then press one of the remaining buttons, usually top right button on most edifices. this toggles between alarm on and off. this shall do....
Posted on Oct 04, 2009
  • 2501 Answers
SOURCE: I would like to shut off the Hourly alarm
I haven't been able to find instructions for your watch but since most watches operate in a similar manner try the following:-
(I assume that your watch had an lcd screen.)
Press the mode button until you reach the alarm setting feature, "AL"? there may be one feature that is specifically for hour repeat "HR"? use one of the other buttons to turn it from "ON" to "OFF".
Press the mode button to return to normal operation.
Some experimentation may be required.
Posted on Feb 17, 2010
SOURCE: Have a louifrey watch and alarm goes off at 4 a.m.
l have a Loifrey japan movement watch with no instruction,could anyone tell me where to get them?l have been on the Louifrey website but couldnt find them,thanks for your help :)
Posted on Jun 17, 2011
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
Thank you :)
Oct 12, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
The alarm on my Casio goes of every 5 minutes, and I do not have det manual because I got it from my brother. Please help me to figure out how to turn the alarm off.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Mar 09, 2011 | Casio Midsize Digital Sport Watch...
I cant stop the alarm from going off every 5 minutes, please assist
The user instructions that the maker publishes are generic only and not model specific, so try go to http://www.genevawatchgroup.com/pdf/kc_reaction/KennethColeReaction_US.pdf and scroll down to the alarm setting section.
With any luck, your watch will be covered by these instructions.
Jan 21, 2011 | Kenneth Cole 1213 Wrist Watch
My son has this watch and loves it EXCEPT for the fact that the alarm comes on and goes off every minute for 30 minutes. How can he make it stop?
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
Oct 30, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
I have an Armitron 40/8125 watch. I try to set the time as follows 1)Hold B - Alarm hours flash 2) Press C - Alarm minutes flash 3) Press C - It goes back to Alarm hours flashing where it should advance to...
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Mar 18, 2010 | Armitron 40/8125BLK Digital Sport Watch
I would like to shut off the Hourly alarm on a rockland RK 4112 Watch
Feb 16, 2010 | Watches
Casio edifice mens watch user instructions needed because i can't turn of the alarm and it goes off at half 5 every morning please help
Sep 09, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
Shut off hourly alarm on g-shock
Okay I have this module so here goes.
Start from your regular timekeeping mode (use lower left buttin to cycle through until you get to the normal time display).
Press 'mode' button (lower left) once. You are now in alarm mode.
Press lower right button to cycle through the alarm modes. The cycle goes: hourly beep on, timed alarm on, both on, neither on. You will see the corresponding icons (a ripple icon for hourly beep and and a bell icon for the alarm) appearing/disappearing in the top left of your display as you cycle through. So if you are in hourly beep mode now you probably need to press that lower right button 3 times to get to 'neither' alarm being on.
Press lower left button to return to normal display.
Hopefully - enjoy the peace!
Jul 05, 2008 | Casio G-Shock G2600 watch
Bulova Watch Logo
206 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
