Water is dripping insider from my mr. slim MSZ09UN unit. Not heavy amounts, but enough to let me know I have a problem. I'm guessing the drainage path to the outside is blocked, but I can't find any imformation on how to clear it.
  • 53 Answers
Okay sir take the unit apart an clean front an back coils THATS IF YOU HAVE A WINDOW UNIT so clean the bottom base an add bleach to system to treat an coat the unit so that slime an other unwanted things wouldnt grow .Now if you have an up flow or horizontal dis connect the primary drain line an blow out with compressed air or an compressor so it would clean out lines, there are many other right tools you could use but these are some of the common things you would have..treat unit with bleach in pan or drain assemb
Posted on May 17, 2010
My Mr Slim inside unit is dripping some water. Solution?
Clean the filter. Shop vac the drain line.
Aug 02, 2017 | Heating & Cooling
I have constant condensation dripping out the bottom left hand side of one of my inside split units and have to keep a pan there to catch it. How do I remedy the problem. Thank You Mark McDaniel...
The highest percentage is to be clogged with dirt Wading in water, should remove the entire mask and left side in Wading, check any rate, the extra drainage Has blocked too
Aug 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Dripping cups of water
The water is condensation on the cooling coil which is normal. If there is a drain you should check to see if it is clogged. Some units use a heater to evaporate the condensation but I don't know if your unit has this feature. Let me know what you find.
May 02, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Water leaking at front of condensor ( inside)unit.
sounds like there might be a blockage in the condensate pan that is not letting all the water drain through the condensate line. if you can access this area try to clean all the debris out
Jun 12, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
A.C. unit
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
YOU CAN LOCATE THE DRAINAGE AT THE LEFT OR RIGHT SIDE OF THE DRAIN PAN
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
