Question about Microwave Ovens
Surface burners , when turning on left front the left back burner comes on,
    President:
  • 1,561 Answers
You should first check the wiring on your knob to be very sure that it is not malfunctioning or having partial contact by touching the back burner mapping or control. if everything is okay there, then you van check the below as well but if not, please fix the partial contact on the knob.
Secondly,Inspect the element to determine whether it plugs into a receptacle, as most do, or is wired directly.
Remove the plug-in element and inspect the prongs: Lift up the front of the element, then pull the element straight out.Check to see if the prongs are burned, pitted or otherwise damaged. If they are, you'll need to replace the element and the receptacle.
Take care.
Posted on May 15, 2010
  • rheox May 15, 2010
    My question was not about a microwave, It is a Kenmore cooktop,and the wiring is ok I have no idea why when you turn on the front left burner the left back burner comes on , but I will retry again. thanks
  • Sulaimon Jimoh Olayemi May 15, 2010
    Have you check the manual to see if theirs is anything relating to this? because one possible reason among others could be that the left front knob is having partial contact with back burner that is why it turns on while the front knob is turn on.
    From the manual, i doubt if this is the way it is been designed but the cause cold be what have stated above.
    Try as you said again and the performance.
    Take care.
GE stove with defective surface unit
Make sure that the replacement is receiving power. If not U need to trace the wiring that goes to the element for the source of the issue.
Also check the power switch to that burner.
Jun 02, 2016 | GE Microwave Ovens
I clean the burners and the ignite it is not working if i used a lighter the back tow burners will turn on but not the front ones
Sometimes when we clean the burners we get some debris or gunk into the gas outlets. I always take a toothpick and clean out the gas openings. Be very careful that you don't break the toothpick off in the opening. Once you've done this, use a lighter at the burner and turn on the gas. You should have a flame. Let the flame burn for about 5 minutes to burn off any more "gunk" that may be in there. Also, if your burners have covers, make sure they are in place before you light the burner.
Depending on the age of your range, you might need to clean around the igniter. Some are concealed and you can't reach them. Those that are not concealed can be cleaned by wiping with a soft, dry cloth.
I hope these suggestions help you get your range working again. If they do, please come back to Fixya and rate my advice!
Aug 15, 2011 | Microwave Ovens
The "hot surface" light will
for the burner problem if the hot light wont go out you have a bad burner, that burner has a limiter on it that tells you when the burner is hot. as for the oven light i would try to change the bulb
May 12, 2011 | Kenmore Microwave Ovens
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
I have a kenmore elite range model number 790 46809 991 and the burner on both the left and right are acting up. They both show that a burner is on on the control panel (not surface indicator) and the...
Hello gralexander,
The problem you are experencing is with you control switches. The cheapest place i can find the switch is from searsparts direct. Here is a link to the webpage http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046809991/0583/0124160/P0050380/00001?blt=06&prst=0&shdMod=79046809991
You will see a diagram in the top left side of the page use it to locate the switches that are bad and order them from sears. You may also need the burners to check them you need a continutity tester.
1. Remove the burner from the socket
2. Take your test and touch one probe to each side of the burner.
3. If you have continunity then the burners are good
4. If not you will have to order burners as well.
Changing the switches:
1. Unplug the range
2. Remove the back panel where the switches are.
3. Remove the knob from the front
4. Remove the screws from the switch you are replacing (Due one at a time)
5. Move the wires from the switch to the corresponding terminal on the new switch
6. Replace the switch and screw in place
7. Do the other switch
8. Reinstall the cover on the back of the unit
9. Plug in and try
Doing all of the above steps should fix the problem that you are having. Please make sure that you install L1 to L1 and L2 to L2 on the new switch other wise you will cross wire it and the rest of the switches will short and need to be replaced.
Thank you for choosing FixYa.com. If you have any other questions please post back to this thread and I will do my best to help you with your Range problem
Justin
Mar 10, 2011 | Kenmore 63252 Microwave Oven
I have a GE 4 burner self cleaning range. it was installed new. I have lived here since 2006 and was the first and only occupant. The stove is lightly used and kept very clean. I prefer my microwave and...
Are the burners warm all the time? If so then this is a problem. Perhaps when you had your incedent were you leaning forward and pushing on the front controls? Or was the container pushing on controls on the top? .....Pushing on the controls can case them to get hot.
YES, you need a GE professional to look at this.
Good luck,
Shawn
Jan 30, 2011 | Microwave Ovens
The light for the right back burner stays on,even though the burner is turned off and is cool
heatman101
Dec 25, 2010 | Microwave Ovens
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
