Question about Maytag PYE2300AY Electric Dryer
Maytag Dryer PYET244AYW won't turn on....
Recently my Dryer quit working and I thought it was the "switch", so I pulled that off and put the two loose wires together via electrical tape. That did not work. So I pulled the top part off (where the start button, buzzer and what kind of a dry you would want is located) and started playing with the OHM Reader/Meter. I have very little experience with this device but I noticed something odd. As I touched the probes to random wire endings of the start button (the one that has "shoter dry, longer dry, etc. on it) the OHMmeter would jump on all of them except the one the WHITE wire connects to. Now I am unsure what to do with that info. Does that mean that whatever that white wire goes to within the dryer is not working, the actual piece that I am checking is not working or something else altogether. Any help would be appreciated. My Dishwasher quit working 2 days later so I need to figure that out as well... :-)
  • 1 more comment
  • Jason Miner May 15, 2010
    I am getting 240 volts from the outlet so that is fine. Are you suppose to check the cord/plug itself? I checked with the OHMmeter and it jumped for the round plug & L shapped plug but not for the two side ones. Is that normal?
  • Jason Miner May 16, 2010
    I believe this will fix the issue...thanks....
  • Jason Miner May 18, 2010
    I included the previous thread below. I just checked the new thermal control I just purchased and the OHMmeter reads it exactly the same. So I would think that there is another issue somewhere. Any suggestions would be appreciated.
    Thanks,
    Jason
    ___________________________________________________________________________________
    Hi
    Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    May 15, 2010 - So is this something that would cause my dryer to completely stop working?
    May 15, 2010 - Yes right, also check for lint buildup around drive motor and Drive motor - start switch contacts stuck closed.
    May 15, 2010 - ok, in trying to identify the thermal fuse, I found something in the front bottom near the vent duct that has 4 or 5 wires attached to it. I put my OHMmeter probes in different combinations on all 5 of them and all but one gets quite the jump on the OHMmeter but when I involve one of them it barely jumps and differs from the rest. Could that be my culprit or is that normal?
    May 15, 2010 - Yes right it can be the thermal limiter from what you have described so you need to replace it.
    May 15, 2010 - Ok, before I set this up to be shipped, I just want to double check. *Smile* It is part 53-2880 and it has 4 wires that were connected to it. When sticking the OHMmeter to it I was getting about 220 OHM's from the top one and the two side ones. The bottom (middle) one was getting 20-30 OHM's. You believe that means the piece is faulty? Thanks again...
    May 16, 2010 - Yes you are right. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Brigadier General:
  • 8,619 Answers
Hi
Thanks
Rylee
Posted on May 15, 2010
  • 4 more comments
  • Rylee Smith
    Rylee Smith May 15, 2010
  • Rylee Smith
  • Rylee Smith
    Rylee Smith May 16, 2010
    Thanks
    Rylee
    President:
  • 2,468 Answers
Did you first check for 240 volts at the unit,then inspect the terminals and make sure all were still intact,these units carry a lot of current and terminals do burn off,if you lose 1 phase of power to the unit the drum will still turn,but it will no longer heat if its a 240volt element,did you check the thermal fuse in the dryer vent housing these go out regularly,then the high limit/cycling switch/thermostat,and ohm out the element all located on the element housing
  • danny Hendrickson May 15, 2010
    please check each wire for continuity or measure the 240 volts at the terminal strip inside the dryer where the cord terminates inside the unit
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
Dryer was in mid cycle and just stopped it has power going to it but it wont run model # is pyet244ayw
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 14, 2011 | Maytag Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Maytag dryer pyet244ayw won't turn on
Most Likely bad fuse! (maybe caused by blocked vent)
Remove power! Unplug! Do not trust breaker!
Pop top, lift top from front (above door).
Heater is in back.
Thermostate on top of heater.
Fuse is beside heater.
Probably bad fuse! (Will read open on ohm meter if bad)
Next would be door switch (Will read open if door open, closed if door closed) Open all times will keep dryer from starting also.
Feb 16, 2010 | Maytag Dryers
Maytag pyet244ayw---the dryer would not turn off.it had to be manually shut off. now, it turned off during a drying cycle. i can hear a whining sound when i tried to restart it.
Could be the belt.
Disconnect power.
Using a putty knife, slide it under the top and front panel of the dryer. There is one clip near each front corner. Pull up on the top panel while depressing the clips.
With the top up, you can see the drum and the belt should be around it and tight. You should be able to rotate the drum with your hand with some resistance. If the belt is not present then it is probably broken and under the drum. If this is the case, the whining you hear is the motor turning under no load.
Please post if this is the problem or if other to assist others with a siimular problem.
Dec 15, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer won't start
thermal fuse is the white platic fuse mounted to the exhaust about 6'' from the blower
easy to get to with a snub 1/4 '' drive
Sep 30, 2009 | Maytag Dryers
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
MAYTAG PERFORMA PYET244AYW
It could very well be a thermostat problem, however, it could also be the drive motor itself starting to burn out. Some dryers are equipped with a "Thermal Limiter" that will cut the power to heat. It doesn't seem to be the case for you. I would defiantely look into another thermostat but if it comes down to the motor, depending on the price, You may want to buy a new dryer.
Apr 01, 2008 | Maytag PYE2300AY Electric Dryer
MAYTAG Heat Element Shield?
not really put the plate back on it helps force the air across and keeps lint out
Jan 30, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
87 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
