Symptoms Philips HDTV
Hi the symptoms are the green lite comes on, and you hear some clicking and the hi voltage whine, but the screen is completely black. no lines, no flicker, nothing. the only other numbers i found is a sticker that says "renewed 070000448100" other than that just the model and serial number. I see no chassis number and have had the back off and everything.
  • 8,617 Answers
I will try submitting a request to philips to see if I can nail down that chassis number, if i can find that out I will be able to help you.
Posted on Mar 30, 2008
I power tv on it lights up for second then flicks off ,
hi look at the back of the tv, to see if you can see a light, if so the inverter is working, if you can't you will need a tech to test the tv's power supply, for voltages, you need 24 volts going to the inverter hope it helps
regards
shaun
Jan 30, 2014 | AOC Envision L27W461 27 in. HDTV LCD...
Philips 47PFL5603D LCD TV ,will not turn on,it did have flashing red lite,insted of green,then it got a clear flashing lite,now there isn't any lite on,I have unpluged it,when you plug it back in,you...
The power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
May 13, 2011 | Philips 47PFL5603D 47 in. LCD HDTV
Philips 30PW850H 30" TV screen is completely
hi,
normally color crt tvs have three guns such as red green and blue. when the voltage at the cathode any of these guns go to zero that color will lead in the screen.
in ur case the green cathode voltage is low. that's why the is green on all over the screen.
if it suddenly came then there is a possibility of dry soldering in the pcb behind the picture tubes neck. we called it as base board. which consist of three transistor or one ic for cotrolling cathode voltage of the guns .
if u have a soldering iron the open ur tv and try to re-solder components in the base board. mainly the component with three leg ( if transistor). if there is ic it will have more than 6 legs . if you can try to re-solder all the points. Be care-full that dot make short circuit when soldering. after care full soldering power on the tv and watch the scree. you problem Will solved.
if u need any further assistance from me, feel free to contact me through fixya.
ok
Jan 16, 2011 | Philips 30PW850H 30" TV
I have a Hitachi Ultra Vison 57S700 2004 model, the TV has had a slight high piched whine for a couple of weeks and today the screen went green then black and the sound was gone. When it is turned on the...
This tv is under five years old?Yes,it is worth fixing.Over five,i would compare the prices for a new LCD tv and the quote priced from the Tv Tech.for the old tv.This tv have high voltage problems around the Deflection circuitries area.Could be any things burn in this area.The high pitched whine sound,i'm sure it is from the FBT-the high voltages flyback transformer,high voltages current have no where to go.Must hire a tv tech. to troubleshoots and replace parts on the Deflection circuitries area.Also the FBT could be dead too,because HV Current bounces back forth and have no where else to go.The prices to troubleshoot unknown problems is about $400 bucks and plus cost of replacement of parts.
Dec 04, 2010 | Hitachi 57S700 57" Rear Projection HDTV
BULBS FIRES BUT SHUTS OFF IMEDDITALY HAS A NEW BULB IN IT BUT STILL NO PICTURE. CAN SEE BULB TRYING TO COME ON BUT SHUTS DOWN WITHEN SECONDES
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. This is the most common failure ,what happens is that the ballast was providing lesser voltage to the old lamp the newer one takes more voltage.You will need to replace it,you can find your part on discount-merchant or partstore.com good luck and God bless!
May 06, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Hello, I have a phillips 1080p LCD HD 47
Replaced the backlight video board,u hear a click light on.The power board work.
Dec 10, 2009 | Philips 47 in. LCD HDTV
My sony clicks green led flashes but no sound no picture a dark screen only...there' s breif sound like a fan blade churning just a few seconds..
Hi,if your tv is 2-4 yrs and have not replaced the lamp it might be time to replace it.Do you hear clicking noises and have replaced lamp before it could be the board that powers the lamp its called the ballast.You can find original philips lamp in here : http://www.discount-merchant.com/SearchResults.asp?Search=XL2100+?Click=48173 Have a blessed day!
Nov 12, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi just relaced the bulb 6 months ago Now tv
If you do not hear anything trying to come on, no fans, or relays clicking, you probably have a Thermal Fuse that has opened. Do to the dis-assembly that is required to replace it I recommend you have a qualified Service person come out to verify the symptom and repair the set. If that is what it is I estimate 400.00 or less to repair the set.
I hope this helps
Skyassoc
Oct 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Philps HDTV
It could possibly be something in the deflection circuits. Exactly what are the symptoms when you try to power up the set? Have you tried to see if you can locate the Chassis number of your set, As a philips/magnavox is almost impossible to diagnose without that chassis number as all service info is crossed by chassis number.
Mar 29, 2008 | Televison & Video
No pic/sound
If you dont here anything then it sounds like the switching power supply or the horizontal output circuits not starting up. this requires troubleshooting with a variac, as well as maybe a scope. If your not trained to work on HI Voltage circuits you should seek assistance with this repair. Theres HI voltage inside these sets even after they are unplugged for a while. sorry i couldnt be of more assistance.
Jun 25, 2006 | Philips Magnavox MS3252S 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
