Computer wont connect to modem
Verizon says network card is configured wrong and we have a red x at our local connection
    Scholar:
  • 58 Answers
Oepn network connections in the control panel ... right click the local area connection and if the first word is enable click on it to enable it ...
Posted on Mar 30, 2008
SOURCE:
The ethernet light on my modem turned off despite the fact that it is connected by wire (tried numerous cables as well) and that the internet service is working. The internet will not connect, and the...
Seems like your computer ethernet adapter (network card) is not working correctly/not installed or mis-configured. Open Network Connection and look for Local Area Connection:
* Does it state Disable underneath it? -> Right-click on it and choose Enable.
* Doesn't exist -> Open Device Manager and look for Network Adapters. Is it there? Do you see any yellow question mark or exclamation mark? If so, reinstall the network card driver! If you don't see any of this then the network card is either not connected firmly to the motherboard or it's defective. Connect it firmly (after shutting off the computer and disconnecting the power cord!) or replace it with another network card!
* Exists and enabled -> Right-click on it and choose Properties. Click Configure, go to Advanced. On Media Type, make sure it's set to Hardware Default or AutoSelect.
Cheers,
Pelu.
Mar 13, 2010 | Linksys EtherFast Cable Modem with USB and...
Cannot connect to internet. I had internet connection over telephone modem before Hard drive crashed. I replaced HD and could not connect to internet. Dell was no help at all. I signed up for Verizon DSL...
I bet you are using the phone modem that canme in your machine. You need to connect the Network card ( Ethernet Card) and make sure the drivers are working. Find it is System, Hardware, device manager, look for ethernet.
Connection icon and see if the netcard driver is installed.Connect the cat5 cable that was sent to you with the DSL modem box. It chould be a yellow cable... It only fits one way and in a maked plug on the DSL modem and into the network card in the computer. Everything there after should go automatically.
Jul 24, 2009 | Dell Dimension 4700C PC Desktop
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
What type of modem do I need?
bridge modem The 2100 modem is a bridge modem only, it doesn't do either NAT or PPPoE. Don't worry what that means, just that it's good news. It is already a dumb plain pass-through, so you won't have to dumb it down so that it won't conflict with the router's functions. I am also going to make a wild guess here that you are in a part of the Verizon network that was GTE before it was bought by Verizon, and are not using PPPoE, but rather DHCP. If you were in an area that was BellAtlantic before Verizon that means you are on PPPoE and you have had your Verizon DSL for 3 or 4 years or longer (about then they started using the 2200 modem for PPPoE customers). Configure your Windows XP PPPoE client as follows: 1) Go to Start >Control Panel >Network and Internet Connections. 2) Select Network Connections under the Pick a Control Panel icon. 3) Click Create a new connection under Network tasks. 4) Enter your area code in the location information (if asked), and click OK twice. 5) Click Next when the "Welcome to the new connection wizard" window displays. 6) Select Connect to the Internet and click Next. 7) Select Set up my connection manually and click Next. 8) Select Connect using a broadband connection that requires a user name and password and click Next. 9) Type "DSL Modem? ( you can use your ISP Name here) for the ISP name, and click Next. 10) Enter your BellSouth username followed by "@ISP NAME (if required by your ISP)" and password. Confirm your password, and click Next. 11) Click Add shortcut to this connection to my desktop and the DSL Modem icon will be added to your desktop. Click Finish. 12) Click the DSL Modem icon to begin surfing. -- Best of luck
Mar 21, 2009 | Westell Wirespeed LiteLine 6000 Modem
My computer cant find my router
  1. Make sure your network cable from the modem to the router is good and connected to the uplink port
  2. If connecting directly try other port
  3. Check local area connection properties
  4. Double click "local area connection"
  5. On the middle box find and highlight "Internet Protocol ( TCP/IP) and click "Properties" button
  6. Make sure "Obtain an IP Address automatically" and "Obtain DNS server address automatically" are the only ones checked and click "ok" button
  7. Make sure "ethernet card" is NOT disabled
  8. Update ethernet card driver if necessary.
Wireless:
  1. Turn wireless switch on
  2. Check wireless connection properties and that Internet Protocol TCP/IP configuration is similar to the above
  3. On wireless properties select "Wireless Network" tab and Add your SSID (wireless network name) if not there and if there Move "Up"
  4. Update wireless card driver
Router:
  1. Double check to see that "Automatic Configuration" DHCP is selected
  2. Double check to see if "DHCP"server is enabled
  3. Check wireless network mode and select correct mode
  4. Check wireless channels and adjust as necessary
Jan 18, 2009 | Belkin (F5D7230-4) Router (587009)
No internet connection
Internet connection solutions
  1. Restart the computer.
  2. Test the jack.
  3. Test the equipment.
    1. Try a different jack that you know works.
    2. Try a different cable that you know works.
  4. Check your computer settings.
  5. Renew your IP Address
    1. [x] Windows Vista
      1. Look for your Ethernet card:
        1. Right-click on My Computer from the Start Menu or on the desktop.
        2. Left-click on Properties.
        3. Click on Device Manager on the left side under "Tasks".
        4. Expand the Network Adapters and look for any yellow exclamation points. Make sure a card is listed.
        5. If there are exclamation points, or if there is no card listed, you need to reinstall the card.
      2. Set your IP address to configure Automatically (through DHCP):
        1. Go to the Control Panel in your computer (in the Start Menu).
        2. Go to Network & Sharing Center.
        3. Under "Network", go to Local Area Connection and select "View Status". In new window, choose Properties at the bottom.
        4. Scroll down "This connection uses the following items" list to Internet Protocol (TCP/IP).
        5. Select Internet Protocol (TCP/IP) and click Properties.
        6. Change to "Obtain an IP address automatically".
        7. After you have changed this, restart computer.
      3. Check to see if your network connection is on:
        1. Go to the Control Panel in your computer.
        2. Go to Network Connections. If you cannot see Network Connections, go to Network and Internet Connections and then go to Network Connections from there.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, double-click on the X to enable.
    2. [x] Windows XP
        2. Left-click on properties.
        3. Go to the Hardware tab and click on Device Manager
        3. Right-click on Local Area Connection and go to Properties.
        4. Scroll down the "This connection uses the following items" list to Internet Protocol (TCP/IP).
        7. After you have changed this, restart the computer.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, click on Local Area Connection and click "Enable."
    3. [x] Macintosh OS X (10.4 or "Tiger")
      1. Look for Network Cards:
        1. Go to the System Preferences panel from the Dock or Apple Menu.
        2. Open Network icon under Internet and Network.
        3. This shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Go to Show and then click on Built-in Ethernet.
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option.
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Then restart and change it back to DHCP to renew the connection.
      3. Set your IP address to "Configure Automatically using DHCP". Under the Ethernet tab make sure that configure is set to "Automatically". Click OK until you are back to the main System Preferences windows.
      4. Check your privacy setting
        1. Go to Sharing under Internet and Network in System Preferences
        2. Under Services everything should be unchecked.
    4. [x] Macintosh OS X (10.5 or "Leopard")
        3. The left menu shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Select Ethernet from the left menu. Go to Advanced.....
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option, "Configure IPv4".
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Click OK.Then restart and change it back to DHCP to renew the connection.
      3. Click OK until you are back to the main System Preferences window.
    // MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED // Call Instance.init() at the very end. REQUIRED var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements bobexample.setStatus('[x] ', ' ') bobexample.setColor('#674a80', '#3b5998') bobexample.setPersist(true) bobexample.collapsePrevious(true) //Only one content open at any given time bobexample.init()
  6. Make sure your computer is clear of all viruses, spyware, and adware.
Oct 03, 2008 | Computers & Internet
Internet connection
The only way to replace the network card is to replace the logic board in this unit, however if you are running 10.5, you can purchase an external USB to ethernet adapter at a local Apple retailer and you can hook the computer to the network through that adapter
Sep 26, 2008 | Apple iMac G4 Desktop
Using External Wireless Card with an Internal wireless laptop
5fa34b4.jpg this works on it's own. like it is needed to connect to verizon wireless internet. your internal on the other hand is designed to work with a home networking equipment such a wireless router (one that is connected to the internet via DSL / Fiber / Cable / etc).
Jun 19, 2008 | Toshiba Satellite A105 Notebook
WE HAVE A RED X ON OUR LOCAL CONNECTION AND VERIZON SAYS A PROBLEM WITH NETWORKING CARD CONFIGURATION SO IT WONT CONNECT TO THE MODEM
ok you need to troubleshoot the connection ... start by going into network connection in the control panel ... right click your local area connection and make sure it is enabled ... are you using XP.. vista...??? the red X means no connection ... check the cable also ...
Mar 30, 2008 | Computers & Internet
Verizon broadband wont connetc though it finds the network on q1 with XP.
If your bills are clear and the service from the ISP is ok then check the drivers for the usb modem , remove the drivers and the software running the modem , remove the modem too . first install the software and drivers then connect the usb when required . The com settings can be configured from the control panel
Nov 18, 2007 | Samsung Q1 Tablet PC
Open Questions:
SBCglobal MAil CuStOMeR Care {1^/855~/536~/5666-} CONNECTICUT This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
%#@~ AmaZon PrImE ReFunD PhOnE NuMbER [+1-85O-812-4OO9] Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 21, 2019 | Amazon Computers & Internet
Computers & Internet Logo
41 people viewed this question
Ekse
Marvin
Marvin
