Unable to edit word documents - Computers & Internet
Cannot edit text in acrobat x pro
you need to uninstall ,format device and re-install next put your characters on the acrobat x pro file you can do it by go c drive program-file,acrobat x pro click it add file again it will work.
Jan 08, 2013 | Adobe Acrobat X Pro
I am unable to manipulate a document after scanning it on our Netsacn 4000
Most of the scanners require that you set up the scan first and the software that comes with them will NOT do much if any editing. Be sure and export the document/photo in a FORMAT that is editable. Then use other software such as photoshop or MSWord to edit the document after. The software provided with scanners is usually pretty lame when it comes to editing.
Nov 18, 2010 | Visioneer NetScan 4000
Unable to convert into a Word document. It just opens a blank document. What is wrong?
The easiest way to convert a word document to .pdf is to simply right-click on the file to see if there is an option to "convert to .pdf"., then left-click on that option.
Hope this helps. :)
Sep 29, 2010 | ScanSoft PDF Converter Professional...
Webworks 7 wizard unable to scan document: While trying to generate a *.CHM file using the Microsoft HTML help template and FrameMaker 7.0 sourcefile, WW throws the following error: Wizard was unable to...
you need to add following entry to maker.ini file present in C:\Program Files\Adobe\FrameMaker7.0 location
Under section API Client add following line
WWPPE7=Standard,WebWorks Professional Edition Plugin,C:\Program Files\Quadralay\WebWorks Publisher Professional Edition 7.0\bin\wwpfm7.dll,all
Please note that path given to wwpfm7.dll may defer depending upon your webworks installation directory
Thanks
Rohit
May 07, 2010 | Quadralay WebWorks Publisher Professional...
I'm unable to edit my Office documents(Word/Excel/PPT)
I had that happen once. I opened the document, then SAVE AS......
Then open the new document and you should be able to edit save, etc.
Good Luck
Feb 16, 2010 | Microsoft Computers & Internet
UNABLE TO MAKE CORRECTIONS TO DOCUMENT
Scanners put a graphic image on your computer that is a "picture" as far as the computer is concerned and therefore, you cannot edit text because it is seen as pixels and not characters. In order to make a scanned document editable, you'll need to use the OCR function in your software (Optical Character Recognition). This is assuming your printer came with OCR software, if not, you'll need to purchase an OCR software package in order to convert images into editable documents. You should be able to find such packages for less than $50.00. Check your documentation (and help files) and look for OCR in the index or search the help files for OCR to see if such software came with your printer software package.
Jan 30, 2010 | HP Photosmart C4240 All-In-One InkJet...
I am unable to edit documents that I have scanned. I have tried to download the OCR driver but I am still having a problem. Please help
If you are scanning text as an image, the image cannot be editred, because the computer doesn't know the image is text.
You have to scan with OCR to edit text.
You can use PaperPort to add text to scanned images
May 08, 2009 | Office Equipment & Supplies
How to copy line diagram from pdf files
moz-screenshot.jpgChoose the tool that selects which is designated by a box with dotted lines and guide it to include your line drawing, then go to the edit menu and choose "copy" which should deposit your line drawing on the clipboard. Open your word document and choose "paste" from the edit menu and your line drawing becomes part of your document.
Apr 20, 2009 | Ahead Software Nero 9 Full Version for PC
Windows XP - 'My Documents" missing!
In windows xp there could be multiple profiles.
Check under c:\documents and settings\
Everything in that folder is a user profile. some are system profiles like "all users", "default user", "Network Service" All the other profiles should be user profiles. In each user profile there is a my documents or a user's documents folder.
You should check there to see if you can find your files.
Mar 22, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
