Question about Dryers
Kenmore electric dryer, model number 86873100, stock number 68731 i am looking around and couldnt find a manual for it. i need to know how to go from a 3 wire to 4 wire plug. the old plug has 3 wires. the new plug is 4 wires, but i am not sure where the ground goes or in which order to hook up the other 3 wires.
    Guru:
  • 351 Answers
Here is a sketch for both hook ups on the dryer ..
Posted on May 15, 2010
Where is the heating element on model # 86873100 Kenmore Electric Dryer Model # 86873100 68731 Serial # M 94966314
Here is the Sears parts site with diagrams and parts listings, look at the Bulkheads parts diagram:
http://www.searspartsdirect.com/model-number/110-86873100/0582/0151200.html
And this might be the right video for replacing the heating element if you need to:
Feb 10, 2017 | Dryers
I have a Kenmore electric model 86873100 dryer the cycle timer knob does not advance and will not shut off due to not being able to advance, what's the best course of action to remedy the issue ?
Well... Your model number appears to be off, a bit. It should start with something like, 110.86873100...
Is this problem occurring in Timed dry, sensor dry, or all modes?
Before buying a new timer, I'd first look at the resistor that feeds voltage back to the timer motor. Make sure it's not open. Also, check to make sure one of the wires didn't fall off of it or burn up.
Also, if this was a Kenmore made by GE, they have two coils in them. If one of the coils burns out, but not the other, the timer will not advance. You'll know it's this type if you have a big, round coil setup right behind your drum.
Nov 03, 2014 | Dryers
Where is dryer belt on kenmore dryer model#86873100
Check the model number again. That number is coming up as a refrigerator.
Nov 25, 2012 | Kenmore Dryers
Kenmore 68731 model 86873100 setting the drying to any of the drying methods, the dial does not move to automatically turn off the dryer.
You have a bad timer motor To verify you will get an ohm meter and remove the wires to the motor.
Check between the motor wires fer continuity. If you have continuity then the next test will verify if the gears are stripped on the motor. Apply power to the timer motor and see if it advances on its own. From looking at your model number I see nothing unusual about the timer.
to get to the[parts list I did 110.36873100. 110 is a the large prefix which ID's the dryer as being a whirlpool model. All kenmores ain't Whirlpool.
Aug 26, 2011 | Kenmore 659 Electric Dryer
What size resistor does a kenmore 70 series electric dryer use....?
none that i know of.what is the model number and what is the problem you are having?there are thermostats,thermal fuses element,timer and motor.open the door.look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,just need the model,it will start with 110. or 417.
Jan 30, 2011 | Kenmore 62602 Electric Dryer
My kenmore dryer model 86873100 will not heat
gas or electric? if it runs, check the heating element for a break. make sure the dryer venting is cleaned or the safety on the heater element will shut off the heat to prevent a fire. you may also need a thermal cut out kit which is mounted on the heater assembly.
Oct 11, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer Model 86873100
hi thanks for the question it looks to me you have a bad thermal fuse located at the back remove the back panel on the air duct you will see a small plastic piece with 2 small blue wires replace this part thanks the appliance doc
Jul 11, 2008 | Kenmore 62602 Electric Dryer
Kenmore Electric Dryer 68731
If still heating, clean out vent and check for kinks. Also, REMOVE PLUG FIRST!! Remove back and remove four screw holding filter duct assembly at bottom left. Pull duct toward rear and reach into bottom of duct and remove lint. Also, wash out filter screen.
Nov 17, 2007 | Kenmore 659 Electric Dryer
Kenmore Electric Dryer Model 68731
does the dryer have a gray back panel if it does then take it off the fuse may be bad its a small 1 in in diamiter white with 2 wires going to it replace it if the dryer has a front bottom panel in front then it is in there fuse is bad that is your problem
Aug 18, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
365 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
