Question about Denon Audio Players & Recorders
Hi I have a Denon DAP-2500 with POA 4400 amps, When starting up cold both sides have equal volume, then the left side drops to about 25 to 50% volume. Fiddling with cds, postions and balance sometimes restores both sides except for last night when nothing would work. This is all used equipment bought this year, but its good stuff. I thought it might be my 25 year old cd player so i got a Musical Fidelity cr308 but with the same results. Any ideas? chumly57@hotmail.com
HI , just found your post . I also have just picked up a denon DAP-2500 pre and 2 POA 4400 amps with klipsch belles, having same probs with power balance i followed some helpfull advise and deoxidized all rca jacks speaker terminals ect. also i opened the pre amp and cleand it even though it was fairly clean, i used cleaner on all switches and volume controll's . WOW I could hear it nice and clean . Next i will clean the amps. hope this works for you as this is great equpment well worth saving.
Posted on Dec 12, 2010
Hookup a pre-amp and equalizer to a Denon AVR 982
Hi
you can choose any input on the Denon and select it from the front panel
setup the Equalizer and the preamp connections and plug it in the selected input on the Denon.
Thats it.
if u haveany Questions dont be a stranger.
good luck
Mar 16, 2016 | Denon Audio Players & Recorders
Denon receiver avr 1506 has sound issues. One side has very very low crackly sound until the receiver is good and warm then suddenly the sound starts working normally on the affected side. Or if I really...
Sounds like a thermal related problem and what comes to mind is a cold solder joint. I'm thinking that the "good and warm" is the circuit boards heating up inside where-as the "really crank the volume" is sound vibration to the circuit board helping to make connection. Try this...1st time turn on with problem present...use a clenched fist to lightly vibrate the chassis on top, bottom and sides. Does this vibration test make the problem disappear/appear? If it is a solder connection be warned...locating and repairing these type problems is no picnic and most often requires the "trained eye" of a electronics tech to locate.
Mar 31, 2015 | Denon Audio Players & Recorders
991 Nissan Pathfinder XE-V6, @160,000 miles, Automatic Transition, 4x4. Replaced left side exhaust manifold gasket, new cap & roter @2500 miles ago, new Platinum plugs @10,000 ago Truck star
run the fault codes to find which sensor is failing from internal heat build up
when allowed to cool it works fine until it gets hot again
Mar 26, 2017 | 1991 Nissan Pathfinder
Avr-f100 surround left and centre working intermittently can anyone help.
The same happens with my POA-F100, but only the center channel is affected (apparently the most important for movie/tv).
Seems to be a malfunction of the speaker relay (you can hear it clicking some seconds after power on). In my case a (sometimes pretty rude) hit on the side of the compartment with the flat hand helps, so the contact just mechanically hangs.
If I find the time I will open up the compartment to see if I can get a fitting spare part relay and solder it in (so I don't have to beat my Denon Setup any more ;-)
Jan 03, 2011 | Denon Audio Players & Recorders
My Kohler Fairfax faucet pressure /flow has dropped (cold)
Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
Nov 08, 2009 | Kohler K-12176-PB Fairfax Single Handle...
Denon avr-2500 left main speakers very quiet.
The Denon 2500 was one of the best ProLogic receivers built, it was a work horse and very little ever went wrong with them.
To make sure you're only supposed to hear right & left speakers, press the Stereo button on the remote. Also recheck your speaker connections - this is the single most overlooked connection problem folks have.
Check the balance control to make sure it's in the center position
Make sure the Tape Monitor is not engaged.
Then, check to make sure that the Pre-Out, Main-In jumpers are connected properly on the rear panel.
If that is not the problem, try pressing the Tone Direct button on the remote (aka Tone Defeat on the front panel).
Jul 26, 2008 | Denon AVR-2500 Receiver
1,035 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
