Question about Dishwashers
PUDDLE OF WATER ON FLOOR MAINLY AFTER WASH IS
PUDDLE OF WATER ON FLOOR MAINLY AFTER WASH IS DONE, ONCE WHEN ALMOST DONE WASHING HOW MUCH SOAP SHULD I USE I'M TOLD I AM USING TO MUCH SHOULD I PUT IN BOTH WASH CONTSINERS? I HAVE ONLY BEEN FILLING THEM HALF FULL
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on May 15, 2010
Occassional leaking of wash machine
The water may be a result of the drain not being able to handle the flow. This can be a result of either the drain hose not being in far enough, a blockage in the drain, or even a slow draining main line in the house. (The above applies if the puddle is from the drain area.)
Mar 31, 2014 | Magic Chef CAV2000 Top Load Washer
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Dishwasher dishes have a film on them after the washing cycle is done --Why? We are using powder soap-shuld we change to liquid soap? Please answer.
All dishwasher soaps in the US recently changed to low-phosphorus formulas.
A typical recommendation is to try a "rinse aid" to help.
It is also possible you have hard water in which case a softener can be helpful.
Dec 17, 2010 | Dishwashers
Puddle of water on the floor after each wash
I've a similar problem and traced it back to the dispenser drawer, but it's clean and fitted properly so I haven't a clue unless it's water pressure which I'm going to check this evening.
Jun 08, 2010 | Whirlpool AWM6100 Front Load Washer
I have a brand new (4 month old) whirlpool washing machine. Not always but once in awhile I get a puddle under the washer. I lifted it up and I don't see any water on the motor or hoses like a seal is...
I had this problem and it turned out to be a leaking soap dispenser. I removed it and resealed it with silicon sealant.
alternately it could be the outer tank gasket that fits on top of the tank under the top outer frame frame.
Also check that TOO high a water pressure is not used to empty the soap disperser
Hope this helps
Feb 22, 2010 | Washing Machines
There is soap left at the end of a cycle from the dispenser. It is trailing down the door and standing in a puddle at the bottom of the dishwasher. The soap that is not in the trap door seems to wash...
Try different detergent types--liquid instead of powder, capsules instead of liquid. Don't put large dishes near the door that might block spray. Check the spray holes in the spray arms for blocking.
Sep 18, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Grey front seal holding water
Old machines used to have a drain hose in the bottom to take that water away however they tended to snap off and allow water to leak on the floor .
On new ones they accept that water will lay in the gasket.
If it bothers you try putting a strip of Vileda cloth into the gasket at the end of the wash to soak it up .
It is bright enough to see and to remind you to remove and dry it.
Add a little Soda Crystal to the soap drawer , thsi softens the water and stops smells
May 21, 2009 | Whirlpool GHW9400 Duet Washer
Water over flowing in soap dispencer Whirlpool sport duet washer
A sock was in between the two tubs blocking the water going tnto the main tub. This caused the water to backup and overflow in the soap dispencer..and all over the floor I then put my hand in between the two tubs and pulled the sock out. Thanks to the expert group for giving me this solution.
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Small brown spots on whites
Nov 15, 2008 | Maytag PAV2300 Top Load Washer
Dishwashers Logo
107 people viewed this question
Top Dishwashers Experts
