Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
My needle is hitting the bottom of the bobbin carriage. I read that the hook should align at the needle eye. what hook, can anyone show me what hook there are talking about?
  • 4,924 Answers
They are talking about the needle position ..and the actual eye of the needle to be in sides and not at you ...aligned with the hook(last) that hold the thread before getting into the needle.....the left side hook ..so the needle will have the eye in a left -right position rather than front back ...aligned...My advice if the needle is hitting the under bobbin ,..is to loose the needle from the screw..and push it inside cause it may be loose from not being well tided and if you sew something thick ...so now it needs to be pushed up in place and screwed again well..and of course the position they mentioned..the eye left right so when you insert the thread to make it in a right to left alignment
Posted on May 31, 2010
How do I set the hook timing for a singer serenade 20
remove any plates so the you can see the needle and the bobbin carrier action
now turn the machine over by hand and watch the needle go down to it's lowest point
the hook part of the bobbin carrier should be near the needle
now turn the machine a fraction more and the hook should be almost at the eye of the needle so that a fraction more the hook passes the eye catching the thread
when you have the hook at the needle but the eye is too low or too high, the adjustment is by the clamp that drives the rod from the shaft at the end of the machine
loosen off the clamp and physically tap the rod clamp up or down until the eye is in position as described
retension that clamp
Oct 25, 2017 | Singer Sewing Machines
Sewing machine
remove the cover over the bobbin section so that you can see the needle bobbin carrier interaction
now turn the machine over by hand and watch the needle go down and start to come up
at this point the hook of the bobbin carrier should be very close to the needle just above the eye of the needle
It is at this point the the needle thread is picked up and run around the bobbin carrier to link up with the bobbin thread
if it is not there then take it in for an adjustment as the adjustment is done by loosening off the clamp on the vertical bar at the end of the machine that moves the needle up and down and positioning the needle in the position described
if the needle is hitting the bobbin and the timing is correct , replace the needle as it may be bent or not in properly
Jun 24, 2016 | White Sewing 2037 Mechanical Sewing...
I am looking at this machin for a freind it wont pick up bobbin thread got me stumped
probably needle/ hook timing is out or needle in incorrectly
the groove faces the cotton , the cut in faces the hook of the bobbin case
the eye of the needle has to be just below the hook in the going up position so that it picks the needle thread up to run it around the bobbin case that is to say that at the point when the hook is at the needle , the eye of the needle should be just above than the eye so the hook gets the thread
anyway by seeing both sides of where the needle goes you will see the action
Nov 30, 2015 | Sewing Machines
Singer 306k Machine was working bery well then needle broke and I cant get the needle to line up with the bobbin case Tried reading manual 100 times Becoming frustrated Pls help
fit the needle correctly as too far up will tilt the needle when you tighten the collar up
there is a stop but it is not very noticeable
turn the machine over by hand (no thread) and see where the needle is hitting the bobbin case. the needle /hook timing may have altered
to check that the eye of the needle should be just below the hook as it reaches the needle
to adjust you will have to take it to a service center.
the needle goes in with the grooved side facing the thread and the cut away bit facing the hook of the bobbin
Sep 13, 2015 | Singer Sewing Machines
I have a kenmore model 38512490 sewing machine and I have the machine and the bobbin threaded and I get three stitches into my fabric and the needle refuses to go down and then when it does go down it...
This may be a timing/needle bar height problem. Remove the needle plate and watch the tip of the hook as you turn the handwheel towards you. As the needle rises your hook should pass just above the eye of the needle. At no time should the needle hit the bottom of the hook assembly. This requires some special tools and skills to fix find an expert in your area.
Aug 05, 2014 | Sewing Machines
Needle breaks due to bobbin case slippage. How do
The maintenance section of your instruction book shows how to install the bobbin case. Be sure the needle is at it's highest position to do this.
The bobbin case should never slip once it is properly installed.
If the needle continues to hit the case, the machine needs to be serviced by an authorized Brother dealer if you are the original owner to prevent invalidation of the warranty.
If you try to adjust the timing you could run into additional problems.
Apr 16, 2010 | Brother CS6000i Computerized Sewing...
Will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Jul 04, 2009 | Janome 6019QC Mechanical Sewing Machine
Needle/Bobbin issues with Bernina Deco 600
Jim!
Perfect phrasing of the question, you have all the lingo/parts down pat!
First make sure your new needle is straight, then check to make sure it lines up in the center of the hole in the stitch plate.
There is basically a 1/2 sheet of papers (we use the fine waxy sticker backing paper as our guages don't fit well .1mm! ) distance between the hook and the needle.
Rotate your hook so that it is aligned with the needle in the center position, there should be 2mm between the top of the needle eye and the bottom edge of the hook.
Dec 29, 2008 | Bernina Bernette Deco 600
Bobbin?
DO NOT RESET THE TIMING!! The timing is off on maybe 1 in 100 modern Husqvarna machines. For the user to change the timing is turning a simple fix into a complicated and expensive fix.
If the top thread is "looping up on the bottom" then you have a problem with the tension on the top thread. Here is what to check:
1. Thread the machine all the way through the eye of the needle. Don't go under the foot.
2. Pull the tread to the side. While pulling, lower the presser foot. You should see the needle bend as the thread gets tight. If not, you have no tension on the top thread.
3. With the bobbin in the case, hold the needle thread and turn the handwheel to bring the thread up. Watch through the cover to see if the thread passes over the bobbin from left to right. When it gets to the right side, the take up lever should pull the slack out and the thread should be pulled up. If it comes part way across but does not pull up, make sure the thread is in the take up lever. If you never see the thread, remove the bobbin case and turn the hand wheel. You should be able to see the hook pass behind the needle while the eye is still below the level of the hook. If the eye is above the hook as it passes the needle from right to left, then and only then consider timing the machine. If the hook passes above the eye but doesn't catch the thread (bobbin case out, needle plate on, presser foot down) you probably have a problem with your needle. Put in a new needle and make sure that the flat side is to the back.
99% of the time when a Husqvarna is not picking up the bobbin thread, something simple has been overlooked. Your symptom of looping on the back of the fabric indicate either a threading or tension issue in most cases, not timing.
Aug 04, 2008 | Husqvarna Viking 1
Needle hits?
OK, this is a general timing procedure. Loosen the screws on the main shaft gear that goes to the hook drive gear and separate the gears. Next put the needle in the left position and bring the needle all the way down by turning the handwheel. As the needle comes up make the point of the hook enter the scarf of the needle (just above the needle eye)and hold it there while you put the gears back togeather and tighten the screws. This should put it close to being in time. To fine tune it you can loosen the needle bar screw (half way up the bar that holds the needle) and adjust theneedle so the hooks point is just above the needle eye. You may have to do this a few times in order to stop it from skipping stitches. Good luck. Rick
Aug 26, 2007 | Singer 20U73
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
