Question about Camelbak ThermoBak 3L
How do I get water out of the tube?
So I need to cut a how in the tube ? Also how do I refill it?
I did not get a insturction booklet with my new pak and I look forward to using it.
Anita Parham
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
No. the mouth piece hole will appear after biting down on it to prise it open
Posted on Mar 27, 2014
2001 cal spa blowing 20 amp fuse in Balboa spa pak
Probably a bad pump motor. Drain and refills are notorious for stuff like that.
Mar 28, 2014 | Dryers
Tip
How to adjust a toilet
  • Your toilet tank may simply need a good "tune-up." Here are some adjustments you can make.
  • Refill valve. If your tank has a conventional ballcock refill valve, the water level is adjusted by bending the float arm. The level should be high enough for complete flushes, but the water should not be to the top of the overflow pipe. Your tank should have a colored or molded water level mark. It should never be set so low that the bowl does not refill with trap sealing water. The rule of thumb is to set the water level about 3/4" below the top of the overflow pipe.
  • If the float rubs on other parts, simply adjust the float arm sideways. If the float lacks buoyancy, unscrew then shake it to determine if it is waterlogged. A waterlogged float should be replaced. The float arm can also be replaced, if needed.
  • In tanks using modern plastic refill valves, the tank water level is adjusted in other ways. If your tank uses a hand nut, turn the nut clockwise to raise, or counterclockwise to lower, the water level. Or, your tank may have a sliding pinch clamp on an adjustment rod.
  • Flush valve. Replacements for a flush ball and its actuating mechanism are available, but it may be possible to stop a leak with minor adjustments. Check the following mechanisms before purchasing replacements.
  • See that the guide arm is centered directly over the seat. The guide arm should drop the flush ball directly into its seat. If the flush ball is not seating properly, make the adjustment shown.
  • The guide arm should allow the flush ball to rise enough for a complete flush. If not, raise the arm. Be careful that it isn't too high–then it will prevent the ball from closing completely.
  • Check that the upper lift wire pulls the flush ball high enough. To adjust it, simply bend the wire for a higher or lower lift.
  • The lifting hardware on a flapper-type flush valve should raise the rubber flapper to start a flush, but should not hold the flapper up off its seat. If this is occurring, the hardware is adjusted too short. Some types allow you to slide the flapper itself up or down on the refill tube to ensure that the flapper meets the valve seat squarely. The lifting hardware and flapper height adjustments are the first things to check when flapper problems arise.
  • Refill tube. If the bowl-refill tube is out of place, water is routed directly into the tank, rather than replenishing water in the bowl. When this is the case, you will likely hear splashing sounds during tank refill. The refill tube should aim directly into the overflow pipe but should not reach below water level. If the tube extends too low, it will siphon tank water silently away. Fix it by repositioning as shown.
  • Defective refill tubes on some valves can be replaced with new plastic ones. Simply place one end of the plastic tube over the serrated plastic lug on the body of the valve, and place the plastic holder in the top of the overflow pipe.
  • on Jan 16, 2010 | Plumbing
    Refrigerant leaking from a puncture in the copper tubing.
    Put in a new piece of tubeing.First cut out hole, swag !a new piece of tubeing on both ends to fit over existing tube after claning and fluxing both ends of all four connecting pieces. Then silver solder all. Refill unit with the correct freon. Ifyournot familuarwith HVAC unitsI would suggest gtting profesonial helpl .
    Sep 30, 2012 | Soleus SG-WAC-08ESE-C 8000 BTU Window Air...
    Toilet tank fills slowly
    My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
    Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
    The water will not refill! The inner plastic part doesn't work and it's only one year old! I must pour a bucket of water into the bowl to flush waste.
    Does this tank have the plastic bucket around the flapper inside the tank. If so this is a water saver toilet. A few tricks to increase the water. I have had to remove the bucket by cutting it maybe half into to increase the gpm.
    This will increase it to more than 1.6 gpm's. It can be cut down just be careful in doing it if this is the problem.
    Next make surethe fill valve has line running and attached to overflow tube. This will fill the bowl with the needed water for it and the tank.
    Next make sure the water is set to the mark either on the tank or the overflow tube. If no mark to within 5/8" to top of overflow tube .
    Jun 27, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
    The water fill tube for the icemaker is blocked.
    Replace the Dual water control valve found on the back of the refrigerator near the floor with a new one and thaw out the entrance where the water goes into the ice maker. Provide a model number found on the inside of the fresh food compartment wall and I'll try to help you find the correct part number for the water control valve. The water control valve is apparently leaking like a leaky faucet and it's freezing causing the problem
    Apr 03, 2017 | Whirlpool Refrigerators
    My toilet is continuously syphoning, i.e. water trickling down the back of the bowl, I have replaced the dump valve seal to no avail, and now suspect the problem is with the mechanism that refills the...
    When you lift up the float does the water cut off like it should? If so you might have your float level to high and its going over the overflow tube. Water needs to cut off before it gets to the top of the tube. Adjust float.
    Oct 04, 2009 | Villeroy & Boch Home
    Nintendo 64 Transfer Pak...
    Try cleaing the contacts on the games and the transfer pak itself, look up how to clean games on youtube.
    Jan 27, 2009 | Nintendo 64 Console
    Nintendo 64 Pokemon Stadium Transfer Pak Error
    Its most likely the controller. When you put in the pack is it loose? You could try cleaning the GB game and trying again.
    Jan 26, 2009 | Nintendo 64 Console
    Camelbak ThermoBak 3L Logo
    344 people viewed this question
    Top Camelbak Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Camelbak Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
