Question about Sony RDR-VX555
VHS TO DVD DUB ERROR ON PLAYBACK
I have been trying to dub from VHS to DVD Sony and TDK brand DVD's and I follow the simple1,2,3 steps as far as insert both disks press dub and done. wait for 2 hours and when the tape in done ok all is done. Well the dvd only seems to play in the SONY RDR VX555 from where it was recorded. MY Apple comp doesn't recognize it nor the XBOX 360 or other dvd players we have arond the house. Is there something wrong. Or it it really only going to play in the RDR VX555?
  • 2 more comments
  • Anonymous Apr 29, 2008
    Same exact problem I've having. Any ideas?
  • bfrick22 May 13, 2008
    Im having the same problem.
  • tolelinda Jan 26, 2009
    I have followed all the instructions put in a new HP DVD+R 16x disk, see that it is formatting and then stops. Inserted the VHS taped hit play and then paused it and hit the button marked <----video and nothing happens. What amI doing wrong?
  • bjtsven2009 Apr 11, 2009
    OK. I finalized the disc & OK to play on PC & Mac, BUT I cannot read the f.VOB files on my Mac (foe video editing).  I continue to surf for possible solutions. Thanks for any help.
Chariot
Had the same problem. I have the Sony RDR VX560 which I presume is similiar. You left out one step after dubbing. You need to "Finalize" in order to play the DVD in other equipment. See System menue or read the Operating Instructions. It would probably been appropriate for Sony to put a footnote in the dubbing instructions. Oh well.
DLA
Posted on Jan 24, 2009
    Scholar:
  • 105 Answers
Sounds like the DVD is not finalizing or not doing so properly. Check your setup options...
Posted on May 03, 2008
SOURCE:
Recorded a movie on the DVR, played it & recorded it onto a Sony DVD-R with the Sony RDR-VX525, I believe it finalized & did everything it should. However, it won't play. It says disk error. I went...
what happened was that you probably chose a disc speed on the DVD that was too fast or slow for the dvd players that you are putting it in to. Try re recording it but when under the DVD section, on your remote, choose REC Mode till it says SP. That one should work on just about any dvd player. I had the same problem with mine. Here is a step by step instruction on how to dub from VHS to DVD correctly. If you follow all the steps, you should be fine :) http://angrytechblog.com/2011/02/how-to-one-touch-dub-vhs-to-dvd-on-the-sony-rdr-vx525/
Jan 20, 2011 | Sony RDR-VX525 DVD Recorder/VCR
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
Vhs to dvd - "simple dubbing" greyed out, help please thank you!
check your software, what are you using???? Free software is available at Burnworld.com
Mar 06, 2010 | Sony RDR-VX535 Player
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Nov 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
JVC SR-DVM600 Dubbing from HDD to DVD Problem
Have you tried using a different brand disc. When I first purchased my DVM-600 it would not record on Memorex discs. I purchased TDK -R discs and all is fine. In the old-school analog world, all specific format tapes were computable to all machines. In other words, a VHS tape recorded in your VHS recorder will play back in my machine and every other VHS machine. Because the DVD format has so many formats and standards, compatability issues are quite common.
May 07, 2009 | JVC SR-DVM600
Won't recognize blank DVD+R disc
Try the next disc in the stack, and see if it will recognize the next one. If not, the problem is most likely the recording speed of the +R disc. Before you go changing disc types, however, I would also check the Record Mode you have set for the dub - if the REC Mode is set for XP, try changing the mode to SP and see if you have any luck. If it still won't work, try one of the tested +R discs:
SONY (2.4x, 4x, 8x, 16x)
TDK (4x)
Mitsubishi (4x, 8x)
Ricoh (2x, 4x, 8x)
-Tha Mp3 Doctor
Feb 14, 2009 | Philips DVDR3320 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Aug 23, 2007 | Sony RDR-VX555
Sony RDR-VX555 Logo
335 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
