Question about Kitchen Ranges
I have a singer computerized futura model # ce 250. the needle is hitting the bottom of the bobbin carriage, is it possibly the timing?
  • 942 Answers
Yes, it is very possible that the timing of its needle in hitting the bottom of the bobbin carriage. Make sure that the needle must not be always at the bottom part, at least near the bottom part to avoid miscarriage...
Posted on May 23, 2010
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
Bobbin case on singer ce250 thread gets hung up and pulls bobbin case out of place
is the needle inserted correctly--flat side goes to the back of the machine
the possiblities are
worn or broken gear
machine could be out of time
needs to be serviced
Feb 27, 2012 | Singer CE-200 Quantum Futura Computerized...
Singer CE250 Futura problems with timing and bird nesting
Needle could be loose or bended or use another size. Put the needle all the way out and the insert a new one inside making sure is the right way in (flat part hasto be looking oposite of you).
another thing is that the Tension could be too tight.
Last, Rethread the machine with another thread to make sure is good.
Hope it helps
Feb 17, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer futura 250. while sewing the E4 code
Are you using bobbin thread? Is your thead new? Is themachine threaded correctly?
Make sure that when you thread the upper part the thread go under the circle that pull it.
Another thing is that when you hit the start button, pull the upper thread until the machine goes two or three times. It helps the bobbin thread to come up and the machine start sewing.I you leave it along the thread sometimes doesnot comes up and that is why the machine beeps.
I use this technique to make sure it doesnt beep and to cut the thread (the one at the beginning so it doesn't mess my design)
Feb 15, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer ce 250 says safety device activated cant find the problemThere is no thread tangled in bobbin case
I just realized my problem... the little thing to put the bobbin on to refill it wasn't quite all the way back to the left. I can't believe it! I'm so glad that I figured out what it was though. Hopefully this information will help someone else!
Mar 29, 2009 | Singer CE-200 Quantum Futura Computerized...
Needle brakes every time
If the needle is hitting the hook under your bobbin case, your machine is out of time. Unfortunately, unless you are familiar with this particular repair, you will need to take it to a qualified repair technician. You can however try a new needle and make sure that it is in properly. If the needle is not bent, then I am afraid you will need to take it in to be repaired.
Mar 01, 2009 | Singer CE-100 Futura Computerized Sewing...
Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Feb 22, 2009 | Singer CE-200 Quantum Futura Computerized...
Needle keeps hitting bobbin case on my Singer CE 100 Futura, it is now jammed completely. Why is this?
either your bobbin case isnt installed right or the machine's timing is messed up try to get needle loose or completly out is preferred then try turning it and see if it comes unjammed if so take your bobbin case out and reinstall it making sure it is in the fit right if this dont solve it then you need to get timing set (not recommended to do at home get pro to do it ) hope this helps you
Aug 20, 2008 | Singer CE-100 Futura Computerized Sewing...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
