Question about Princeton Digital VL1918 Monitor
My Dell monitor will go blank and begin flashing on/off and you are not able to see anything at all. I can adjust (retilt or move) the monitor screen and it will come back on and the screen will return to where it was when it started flashing. While the screen is flashing on/off (the on/off button) I am not able to turn the monitor off using the on/off button. What could be causing this??
    President:
  • 1,138 Answers
Have it check by a technician.. the cathode light on your monitor may be busted already... its easy for the technician to replace it, if that is the cause of the problem
Posted on May 15, 2010
I have 2 monitors my main monitor is blank and I can only see the 2nd monitor. How do I move the main monitor to the 2nd screen?
Right click on desktop and click adjust resolution or something similar, then you'll have the option to activate the other monitor and arrange the desktops in however way you like them
Aug 20, 2014 | Dell Computers & Internet
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
My DELL LCD monitor keeps flashing after the computer shuts down
Try to set the monitor in the factory setting this will discharge the monitor and restore it in the factory settings.
Nov 23, 2009 | Dell E173FP 17" LCD Monitor
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
The text is too tall and not wide enough. How do i adjust the monitor?
If you are using Xp right click on a blank spot on the desk top select properties,in the display properties you will see settings.There is a option to adjust the screen size,move the bar to the left will increase the size.Under vVsta you will right click on a blank spot on your desktop select personalize,select display settings there you can adjust the bar to the left to adjust your display.Remember to apply the changes before you exit.
Good luck
Sep 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Screen is blank but can still see cursor
HI, ON THE UPPER OF YOUR KEYBOARD THERE IS A KEY THAT THE SIGN v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} b\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} 280 7772400 10058400 259 261 257 275 262 278 1 01[;?IN3)?T&<$N9H&7JY+0 5 1 0 281 False 0 0 -1 304800 243 True 128 77 255 3175 3175 70 True True True True True 277 134217728 8 Empty 16711680 52479 26367 13421772 16737792 13382502 16777215 Bluebird 22860000 22860000 (`@````````` 266 263 5 110185200 110185200 True True (``````````` (``````````` 0 419100 428625 clip_image001.gif moz-screenshot.pngOR SYMBOL LIKE YOU A SUN. PRESS THAT KEY THAT WILL ADJUST THE MONITOR BRIGHTNESS.
Aug 13, 2009 | Sony VAIO Notebook
Picture is far too large, exceeds screen, colour cannot be adjusted to anything but very bright. Screen now flashes while on line.
on your crt's manual menu you can resize the screen hit the menu button on your screen to begin or you can try the auto button
May 09, 2009 | Sony CPD G420 19" CRT Monitor
My E172fp has a blank screen...when i unplug and plug it back in,the "dell dimension" or whatever that logo is comes on for a second, then the screen goes blank and stays that way.another monitor works...
i have the same issue before with my DELL 2001FP, I replace the 3 capacitor on the board that look like defective because the top is look like swolen, it should be flat. I replace it with the same value and now the it works better.
i hope this might help .
Feb 25, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Monitor 2001FP Blank Screen
From your description your backlight is going out. The fluorescent light when it begins to burn out tries to draw too much power. Your inverter is sensing this 'too much' power draw and shuts down power to the back light. Replacing the backlight is the most technically difficult repair of an LCD, and most repair shops don't even offer this service. I recommend that you sell your LCD 'AS IS' on eBay or a similar website. The Power board and the Control Board are both usable parts that can be easily salvaged from most Dell Ultrasharp monitors.
Oct 05, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Princeton Digital VL1918 Monitor Logo
132 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
