Question about RCA 25202RE3 Corded Phone
RCA executive series
1. No ringer
2. Line 2 stays lit with red light
3. Voice mail stays lit
  • Anonymous Apr 14, 2009
  • 81 Answers
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
Posted on Mar 30, 2008
How do I stop the red message light from blinking after I have received my messages
~*~*~ SOLVED SOLVED SOLVED! ~*~*~ After talking to both ATT and RCA with no success...I figured it out. ~*~*~ Plug your phone line into the "DATA PORT" on the back of the unit. Slide the "DATA PORT" switch to whichever line is showing it has a message. Press the corresponding Line# button on the front of the phone. (you should hear the dial tone) Dial your voice mail number. Let it answer, (enter your passcode if needed), then hang up! - That's it! example: MSG Waiting:L2 - I plugged the phone line into the Data Port and moved the data port switch to "2". I pressed LINE 2 on the front of the phone, dialed my voice mail number, it answered, I put in my passcode. (It said that I did not have any new voice mails), then hung up! That's it! Message Indicator light off!!! Repeat for each line that shows a (false) message waiting. ~~~Don't forget to move your phone line back into it's correct port on the back of your phone.~~~
Jul 06, 2012 | RCA 25414RE3 Corded Phone
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
Jul 05, 2011 | RCA ViSYS 2-Line Speakerphone
Red Message List stays lit solid even when there are no messages.
No, it stays lit because there *are* messages, just not voice mail messages. Press the MESSAGE button and look at the display. Look at what's above soft key #3. If you don't need the information in the first line, use the CLEAR key to erase it.
Carl
Apr 04, 2011 | Panasonic KXDT343 Phone
So much static I can not hear properly
The line that stays lit for line 2 is just the way it is.. not a problem. If you only have one phone line and a two line phone you will always have the one (non working line 2 ) lit.
Have you replaced the cord to the handset? Many times it is a bad cord that causes static.
May 11, 2010 | RCA ViSYS 2-Line Speakerphone
Have an RCA executive series. the light for the
I have an RCA Executive Line 4-line phone. I was away for a week, and came back to find the speakerphone when I dial out is significantly muffled on some of the lines (people that I am calling complain of noise on the line). If I take it off speaker, the quality on the handpiece is normal. First, I thought it was the batteries, so I replaced them. Didn't change. Is there a reset? Is the phone (base) after less than 1 year defective?
Sep 30, 2009 | RCA Lands Phones
I think that just means that you do not have a 2-line connection to the phone. Either your cord is a 1-line cord or your 2-line cord is plugged into the wrong jack on the back of the phone,
Apr 14, 2009 | RCA 25202RE3 Corded Phone
Line 1 stays lit
do you have your phone plug, inserted into line 2?
Aug 31, 2007 | RCA 25202RE3 Corded Phone
Misplaced manuel, how do you set voice mail to come on after 3 rings
Go to http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=11&idproduct=11 and click on the Download Instruction Book link.
Jul 19, 2007 | RCA 25414RE3 Corded Phone
I need to add voice mail to my phone. Do you have a manual?
I assume you mean you want to add your voicemail's phone number to your phone for a quick dial.
1. Menu
2. use the Review arrow keys and go to VM Code; press Select/Save
3. for Line 1 voicemail, press Select/Save then enter the voicemail's phone number. (Note there is a Pause/Redial button on the left of the keypad if you need to add pauses.)
4. Press Select/Save
5. Exit to get out of the menu.
Apr 19, 2007 | RCA 25202RE3 Corded Phone
RCA 25202RE3 Corded Phone Logo
554 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
