Question about Kitchen Ranges
The needle is hitting the bottom of the bobbin carriage, is the timing off?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Is the bobbin case pushed all the way in? Is your needle up too high or down too low in the needle holder? The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool and then re-thread the machine. Try lowering it a little and see if that helps and use a scrap of material to test it out. Make sure the flat part of the needle rests on the flat part of the holder. You probably need to insert a new needle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 15, 2010
  • pam daniels May 15, 2010
    When I completely take the bobbin carriage out and move the needle down, it hits the bottom of the carriage holder. My screw to adjust the needle height is behind, not on either side of the needle holder and I can't get to it to adjust it, any more suggestions?
  • Rylee Smith
    Rylee Smith May 15, 2010
    If you cannot adjust it then try to check the timing as it might not be working.
My Janome 1600p bobbin case won't lock into the hook. Also when the needle is in bottom position it hits the hook mechanism. The manual doesn't offer any help with this. Any suggestions?
Verify you are using the correct bobbin for your machine. Some bobbins are very close, but any slight variation will cause problems.
Be sure you are using a brand new needle. If it is still hitting, then the machine may be out of time. Search for sewing machine timing or take it for service.
May 23, 2017 | Janome Sewing Machines
My brother LS-2725 is sewing perfectly on surface but has large loops underneath.
Three main reasons for this issue:
  • The cotton is not threaded correctly> Cotton not in tensioner correctly, cotton threaded through needle backwards etc..
  • Bobbin not seated properly so not allowing cotton to loop over smoothly.
  • Bobbin carriage is damaged (usually by forced needle hitting it) Usually this is the tip of the pickup on the carriage is bent.
Hope this helps.
Jul 14, 2016 | Brother Sewing Machines
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
Pfaff 1472
make sure that the needle was put in the needle holder correctly and tightened into the needle holder correctly..
if the needle was in the needle holder correctly and it's still hitting the bobbin carrage then the machine needs to be checked to see if the sewing machine needs a adjustment
Aug 17, 2013 | Sewing Machines
I broke a needle while sweng,now my needle hits my bobbin case on my 2030
it's very possible that when you broke the needle it caused the machine to go out of time & would have to be retimed at a sewing machine repair shop
Mar 12, 2012 | PfaFF Tiptronic 2030
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Needle hits?
OK, this is a general timing procedure. Loosen the screws on the main shaft gear that goes to the hook drive gear and separate the gears. Next put the needle in the left position and bring the needle all the way down by turning the handwheel. As the needle comes up make the point of the hook enter the scarf of the needle (just above the needle eye)and hold it there while you put the gears back togeather and tighten the screws. This should put it close to being in time. To fine tune it you can loosen the needle bar screw (half way up the bar that holds the needle) and adjust theneedle so the hooks point is just above the needle eye. You may have to do this a few times in order to stop it from skipping stitches. Good luck. Rick
Aug 26, 2007 | Singer 20U73
Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Apr 22, 2007 | Singer 7466 Mechanical Sewing Machine
Kitchen Ranges Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
