Question about Vtech Lands Phones
I have a vtech Digital Answering System, model #16777. I had been with Bell Aliant and have switched to Eastlink Communications. Before, I did not have any "crackling sound" interference when using the phone. Now I do with Eastlink. Is there a way to change channels on this telephone, or does anyone have a solution to my problem? JM
SOURCE: Lucent Digital Answering Machine Model 1715
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=161
Posted on Oct 23, 2007
SOURCE: conair digital answering system
TAD2012 Quick Reference Guide
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit will shut down until the power is restored. One 9-volt battery must be installed to retain your personal greeting message and incoming messages during the power failure. Occasionally outside factors, such as power surges, may adversely affect the unit. If the unit is not operating properly or if the light continues to flash once power is restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Conairphone™ Consumer Hotline
Questions? Call the Conairphone™ Consumer Hotline, toll-free, 1-800-366-0937.
Hotline Hours: Monday-Friday 8:30 a.m. - 9:00 p.m. (EST)
Saturday 8:30 a.m. - 12:30 p.m. (EST)
7475 North Glen Harbor Blvd.
Glendale, AZ 85307
Posted on Jan 29, 2008
  • 3 Answers
SOURCE: changing phone channel frequency
Easiest way take off back plate un hook battery wait a couple of minutes hook battery back up phone should find reciever on diff. channel
Posted on Sep 06, 2008
SOURCE: DIGITAL ANSWERING MACHING (VTECH MODEL# IA-5874)
I would doubt it.
Sorry
Posted on Oct 19, 2008
  • 68 Answers
SOURCE: deleted a message on vtech digital answering machine
Unfortunately, once a message has been deleted, there is no way to get it back.
Posted on Dec 09, 2008
Vtech phone model 16777, how do I set up my answering machine?
If you mean the VTech I6777 (letter i not digit one), then follow the instructions beginning on page 26 of the manual: http://cdn-media.vtechphones.com/ecp/documents/product_Product/73/UserManual/185/I6777_Manual.pdf
Sep 06, 2014 | Lands Phones
How do i changse number of rings on my vtech
The CS6114-11 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on your answering machine, consult its documentation. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 30, 2014 | VTech Communications Vtech Cs6114 -...
Answering machine
Enter the model of your VTech 5.8GHz system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Jan 07, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
HOW DO I GET MY MESSAGES FROM MY VTECH CORDLESS PHONE BY USING MY MOTHER'S PHONE
Since you again neglected to specify the model of your VTech DECT 6.0 phone, I can only suggest you enter the model number into the search box here to download a copy of the manual.
Sep 13, 2012 | Vtech DECT 6.0 Cordless Phone with Digital...
VTECH DIGITAL ANSWERING MACHINE CORDLESS PHONE,COM
Enter the model of your VTech system into the search box here to download a copy of the manual.
Feb 10, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
How do i retrive messages from my 5.8 vtech answering maching from a different phone
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download a copy of the manual to learn how to switch modes.
Sep 06, 2010 | Vtech 5.8GHz Expandable Cordless Phone...
Problem with my Vtech digital answering phone 5.8 ghz
I found my paper manual. Also was able to go on line and put in the model number of my VTech and then able to download a manual.
Mar 22, 2009 | Vtech 5.8GHz Expandable Cordless Phone...
Instruction Manuel
Since you neglected to specify the model of your VTech 5.8GHz system I can only suggest you enter it into the search box here to download a copy of the manual.
Dec 22, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Lands Phones Logo
156 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
