Question about GE Nautilus 24" Built-in Dishwasher
Dishwasher leaking out the bottom of the front door
My dishwasher leaks out of the bottom of the front door....I bought it used and looks like maybe there was a seal there before, there is a brown streak running along the seal that is there?
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on May 15, 2010
How to stop dishwasher from leaking out of the bottom left corner?
follow the next steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenses ed19f28b-0f72-4aa8-a09e-69699854be01.gifgasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Jul 06, 2013 | Dishwashers
Leak at bottom of door
see this causes and use the common sense. God bless you
Door Seal
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
Sep 19, 2012 | Maytag Dishwashers
Leaking from the front
I had same problem but different model #.
The part under the spray arm came lose and the gasket was hanging out. Causing it to squirt water right at the bottom of the door and leaking out. I took it apart put the gasket back in the groove, screwed it back down and is working great.
May 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
Dishwasher leaking from the door
Might want to change the door seal if its coming from the door.
Dec 30, 2009 | Hoover 24 in. HD83M Free-standing...
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwasher leaks out front
If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and cause water to spill over out the bottom of th door. Use rinse-aid for better drying performance
May 29, 2008 | Dishwashers
Door leak
Br, couple of things you can look for here. Check the vent, you can just pop this out. Sometimes there is a buildup of gunk which will hold water during wash and leak down between the door. There is a seal there, part number 974782. Another thing is to check the upper spray arm for cracks or splitting. This can send a direct flow of water into the vent. There is also a seal at the bottom of the upper spray arm, part number 3376846. I was fooled by a leak like this once, it turned out to be a clogged vent...Catriver..post back.
Sep 30, 2006 | KitchenAid 24 in. KUDS25 Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
312 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
