Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
Motorola Z3 Blank/White Screen
Cracked my screen and when I tried to replace it with one I bought off eBay I got nothing but a white screen when I turned it on! Returned that screen and got another one from a different seller and still get the white screen. So I'm thinking its not the LCD screen, unless I just have bad luck. The keypad is also new, but now I'm gonna try to replace the ear piece flex cable set, because I can't figure out what else could be wrong with it. The phone powers on and operates as normal (calls incoming/outgoing with texts); I can even hear out of the ear piece. I've also tried to reset it by updating the software....
So... Have any ideas?
  • usafsgt Apr 08, 2008
    Did you ever figure it out, I have the same problem!
    Brigadier General:
  • 7,752 Answers
Replaced the flexcable on the phone.
USA - replaced either the flexcable and LCD
Posted on Aug 28, 2008
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Oct 08, 2009 | Nokia N70 Cellular Phone
Blank white
i just removed the battery and wiped and set on the phone and found the display screen back to normal.
Sep 17, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Blank or White screen on new Motorola Krzr k1 cell phone
i am having a same problem with my krzr phone. it is picking up the screen. solve if you can
May 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia N95 8Gb fell,screen is white.
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
Apr 05, 2009 | Nokia N95 Cellular Phone
RIZR Z3 Showing white screen and shutting on/off
You should contact the people or person from whom you obtained the phone if still in warranty. As the phone might be dead, at which you cannot do anything. Hope I Helped!
Jan 28, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
MOTOROLA Z3 PROBLEM
I've got the same problem!
Cracked my screen and when I tried to replace it with one I bought off eBay I got nothing but a white screen when I turned it on! Returned that screen and got another one from a different seller and still get the white screen. So I'm thinking its not the LCD screen, unless I just have bad luck. The keypad is also new, but now I'm gonna try to replace the ear piece flex cable set, because I can't figure out what else could be wrong with it. The phone powers on and operates as normal calls (incoming/outgoing with texts); I can even hear out of the ear piece.
So... Anybody have any ideas? anybody? breaker breaker...haha
Mar 27, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Blank screen
can be the flux contect(lcd to pcba flux)loose
can be debug by-assble again the flux
Feb 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
White screen
I have the same problem with my z3. I left my phone on the table, and all of a sudden, my normal screen was replaced by a flashing white screen. I called T-Mobile, and they had me try to reset the phone. You can do this by going to settings, then Master Reset. This will restore the original settings, and the rep said that sometimes this helps. Master Clear is the next step, which wipes everything off the phone. Nothing has worked for my phone, so I have to call Motorola today to try and get a new one. Good luck with your phone.
Aug 21, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
253 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
