Ariston AVXL 108 At switch ON draining starts and continues even with empty drum - then the (quick wash + extra rinse) indication lights flash every second + ON light flashes repeatedly. To switch off is necessary to remove the power.
  • Washing Mach... Master
  • 19,396 Answers
Hi.
the problem is likely the pressure switch. In normal conditions the pressure switch will open the circuit to drain pump when no water is detected. If the switch is faulty the drain part of the cycle will not stop.
If the pressure switch is not faulty, then the electronic control board is defective.
As said, the problem is usually the pressure switch.
The parts can be ordered ringing Ariston. The phone number is listed on the owner manual.
Here also a third party distributor in UK.
Regards.
Ginko.
Posted on May 15, 2010
  • francosotgiu May 17, 2010
    Hi
    Having
    removed the pressure switch the pump keeps on running.
    I am looking for user manual for washer maskin ariston AVXL 125
    This should do it.
    http://www.manualslib.com/products/Ariston-Avxl-105-3182207.html Ariston AVXL 105 Manuals
    Sep 02, 2015 | Ariston Technologies Washing Machines
    Hi there I need the manual for AUXL105
    Do you mean the Ariston AVXL 105? Manual Lib has the manual here: http://www.manualslib.com/products/Ariston-Avxl-105-3182207.html . The English part of the manual starts on page 13. The section on the programs is on page 18.
    I hope this helps.
    (The link: http://www.manualslib.com/manual/644893/Ariston-Aml-119.html#product-AVXL%20105 has the link to download the manual.)
    Mar 02, 2015 | Washing Machines
    AMD 121 won't shut off, or change cycles. Continuously "hums".
    Did you try just unplugging from the wall outlet, and let sit for 15 seconds and plugging back in. Sort of like a re-boot on the computer? Just a suggestion.
    Jun 30, 2014 | Ariston Technologies AWD 121
    Ariston avxl 129 washing machine has stopped working.
    This washer does not have a good track record. There are many many complaints out their on this brand in general. It is also not a cheap purchase.
    1st. Suspect is the mother board followed by the motor.
    Nov 20, 2011 | Washing Machines
    Hotpoint Aquarius cycle not finishing with f02 error
    Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
    Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
    Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
    there may be something stuck in the pump itself. hairgrips and brawires are a common find.
    Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Ariston a1636 washing machine
    I have the same problem, did this get solved for you?
    Jan 08, 2008 | Ariston Technologies AW149NA Washer
    Ariston 6kg washing machine
    Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
    Oct 07, 2007 | Ariston Technologies AWD 121
    Ariston Washing machine A1636 - Flashing lights
    what 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
    Jun 20, 2007 | Ariston Technologies AW149NA Washer
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
