Hi, hi have a problem on an HP Proliant DL585 g1. after a reboot the system wasn't booting anymore, i discovered it was one of the four Processor Power Module. since the sistem cannot work with 3 processor i have to run it with two... i want to buy a spare part, and on the ppm i can se: 12v DC INPUT Spare PN: 383331-001 G.P.N.: 383265 i found this on the net: http://www.pchub.it/uph/laptop/623-29886-7099/Compaq-ProLiant-DL385-Rack-Server-regolatore-di-tensione-per-il-server.html? all the code are the same, but that one is from compaq, and mine from hp. allso processor model is the same... allso the circuits on the board are the same more or less... but the metal part is slightly different. since i run the server for study pourpose, and i have no IT budget to spend, i prefered to find a shop in italy, or in europe at the least. would you think that that one is suitable for me?
  • oloap88 May 15, 2010
    thank you, that shop is in italy, and the wil deliver in 2 days, my quaestio was if the par was allright for me or if i have to look fro hp part maybe in usa with 80$ of shipping rate instead of 10... so thanks!
  • 6,993 Answers
I think it would be better if you buy the one on the internet, that is, the one you saw on the website. It would save you a lot of stress because it will be delivered at your door step.
I assure you that the compaq you saw on the internet is the same with your hp, irrespective of the slight difference. Compaq is the same thing as HP, they both use the same drivers and software, they bare different names but they are the same. So there is nothing to worry about concerning the name of the product.
So I would suggest you order for the part from the above link that you first check.
Good luck.
Posted on May 15, 2010
Unable to boot HP DL380 G4 with display message no signal on the monitor
Just Clear NVRAM (by SW6 maintainance switch )/ else systemboard has to be replaced
Aug 11, 2012 | HP Compaq ProLiant DL380 G4 Server
Help with reboot message for Asus G1 notebook.
Sounds like its trying to boot from the Optical drive (cd/dvd drive) thats empty or has no disc in it. You will need to get into the BIOS and change the boot sequence. Select HDDR 1st to boot from your C: drive where your OS is.
Dec 15, 2011 | ASUS G1 Notebook
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
Compaq dl380 g1 - 1611 Power Supply 1 Fan Failure Detected
it only ur fan problem which one of the four fan or two ,might be stuck or jammed which starts after of couple of restarts, so i sugest u to check the fans when in operation
good day
Jun 01, 2010 | HP Compaq Proliant DL380 G1 Server
HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mar 19, 2009 | HP Compaq ProLiant ML350 G5 Server
Amber light flashing on drive on compaq dl585
Sounds like a pre fail alert from the drive itself
Feb 17, 2009 | HP Compaq ProLiant DL585 G2 Server
Hp proliant ml370 g4 rebooting problem
Try to boot from smart start and do offlinr diagnostics.have you purchased second cpu seperately? Check the CPU compatibilities.
Jul 16, 2008 | HP ProLiant ML370 G4 Server
Erorr 805 processor not supported
Is your server under carePAQ/ support by HP.
Please go to the System Settings/BIOS of the server by pressing F9 while booting. Check for error messages.
Please check for the processor support matrix also. You may want to try upgrading the motherborad firmware berfore loading this proc.
Cheers,
Jul 09, 2008 | HP Compaq ProLiant DL380 G4 Server
Computers & Internet Logo
David Payne
David Payne
