WE HAVE A RED X ON OUR LOCAL CONNECTION AND VERIZON SAYS A PROBLEM WITH NETWORKING CARD CONFIGURATION SO IT WONT CONNECT TO THE MODEM
    Scholar:
  • 58 Answers
Ok you need to troubleshoot the connection ... start by going into network connection in the control panel ... right click your local area connection and make sure it is enabled ... are you using XP.. vista...??? the red X means no connection ... check the cable also ...
Posted on Mar 30, 2008
I got a dell x51 pda it has a ambicom 56k modem card...how do I use the card to connection the internet?
You need to configure "Dial-Up Networking", and you need to find an Internet Service Provider in your "local" telephone-calling area that still offers "dial-up" service, and sign-up with them.
They can provide instructions on how to configure dial-up networking to their setup.
Jul 14, 2011 | AmbiCom EZJack CF56M-EZ (480977) Modem
The ethernet light on my modem turned off despite the fact that it is connected by wire (tried numerous cables as well) and that the internet service is working. The internet will not connect, and the...
Seems like your computer ethernet adapter (network card) is not working correctly/not installed or mis-configured. Open Network Connection and look for Local Area Connection:
* Does it state Disable underneath it? -> Right-click on it and choose Enable.
* Doesn't exist -> Open Device Manager and look for Network Adapters. Is it there? Do you see any yellow question mark or exclamation mark? If so, reinstall the network card driver! If you don't see any of this then the network card is either not connected firmly to the motherboard or it's defective. Connect it firmly (after shutting off the computer and disconnecting the power cord!) or replace it with another network card!
* Exists and enabled -> Right-click on it and choose Properties. Click Configure, go to Advanced. On Media Type, make sure it's set to Hardware Default or AutoSelect.
Cheers,
Pelu.
Mar 13, 2010 | Linksys EtherFast Cable Modem with USB and...
Cannot connect to internet. I had internet connection over telephone modem before Hard drive crashed. I replaced HD and could not connect to internet. Dell was no help at all. I signed up for Verizon DSL...
I bet you are using the phone modem that canme in your machine. You need to connect the Network card ( Ethernet Card) and make sure the drivers are working. Find it is System, Hardware, device manager, look for ethernet.
Connection icon and see if the netcard driver is installed.Connect the cat5 cable that was sent to you with the DSL modem box. It chould be a yellow cable... It only fits one way and in a maked plug on the DSL modem and into the network card in the computer. Everything there after should go automatically.
Jul 24, 2009 | Dell Dimension 4700C PC Desktop
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
Verizon DSL spotty service
to answer your first question, call verizon to fix the line. it is dropping. Second have verizon change a dsl and test it out.
as far as the tab on the CAT-5, the tab is to lock the cable in place, without it, it will work but you have no insurace as to the connection status. (need cable with tab).
Jan 18, 2009 | Computers & Internet
Internet connection
The only way to replace the network card is to replace the logic board in this unit, however if you are running 10.5, you can purchase an external USB to ethernet adapter at a local Apple retailer and you can hook the computer to the network through that adapter
Sep 26, 2008 | Apple iMac G4 Desktop
Constant intermittent loss of connectivity, even with new gt704wg router
It might be that you have a voltage drop. I noticed that this modem is very sensitive to voltage 'dips' and it will 'reset' itself if even the slightest dip in power hits it.
I have a A/C that sucks power when it cycles and every time it does I lose the internet connection. So I set up a 12 volt battery with an DC to AC inverter and run the modem off of battery power.
That might be the problem your having.
Aug 26, 2008 | Actiontec GT704WG Wireless Router...
Using External Wireless Card with an Internal wireless laptop
5fa34b4.jpg this works on it's own. like it is needed to connect to verizon wireless internet. your internal on the other hand is designed to work with a home networking equipment such a wireless router (one that is connected to the internet via DSL / Fiber / Cable / etc).
Jun 19, 2008 | Toshiba Satellite A105 Notebook
Computer wont connect to modem
oepn network connections in the control panel ... right click the local area connection and if the first word is enable click on it to enable it ...
Mar 30, 2008 | Computers & Internet
Verizon broadband wont connetc though it finds the network on q1 with XP.
If your bills are clear and the service from the ISP is ok then check the drivers for the usb modem , remove the drivers and the software running the modem , remove the modem too . first install the software and drivers then connect the usb when required . The com settings can be configured from the control panel
Nov 18, 2007 | Samsung Q1 Tablet PC
Computers & Internet Logo
David Payne
David Payne
