Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite H3 Dryer taking longer than normal to dry clothes
My wife just told me the dryer is taking 2 cycles to dry clothes when it used to only take 1. Wondering if maybe a setting may of gotten bumped or something? I checked the vent tube going outside, and don't see any lint build-up, and there appears to be plenty of warm air venting out. Any thoughts?
  • 1 more comment
  • Anonymous Mar 30, 2008
    I have been having this same problem for about a year. Very frustrating and it really defeats any purpose of having an energy efficient applicance.
    I checked the line for any build up of lint and did not find one. Sears technicians told me to rub the dryer sensor with alcohol and that did not work either. Frustrating.
  • flogur Apr 02, 2008
    The dryer ducting only goes 4 feet from the dryer to the exterior wall, so I pulled the dryer out and checked the full length of the ducting. No build-up or obstruction of any type. Also - ducting is not vinyl or plastic. Any other suggestions?
  • flogur Apr 27, 2008
    We called Sears service to come out and service the dryer. They gave us an option when we called to purchase a one year warranty coverage for $200 that would cover the service call and anything that needed repair for the next year. The service call was $65 plus whatever parts were required for the service. We agreed to the one year warranty plan. When the Sears repairman came out, they said it was the sensors that are located just inside the dryer door behind the lint screen that needed cleaning. If you poke your head inside the door and look down you will see the 2 sensors. They can be cleaned with a cotton ball and a little alcohol. The repairman also used some very fine sandpaper to clean the surface. Very easy fix, and no need for a repairman or purchasing an extended warranty. The dryer works fine now.
    Novelist:
  • 184 Answers
EVEN THOUGH THERE IS WARM AIR COMING OUT THE EXHAUST, IT STILL MAY HAVE A RESTRICTION IN THE DUCT WORK. DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER FOR ONE LOAD OF LAUNDRY. IF IT DRYS THE CLOTHES O.K., YOU HAVE A RESRICTION SOMEWHERE IN THE EXHAUST.
NOTE: DO NOT USE VINYL OR PLASTIC DUCTING. VINYL IS NOT U.L. APPROVED. PLASTIC PVC WILL ALLOW CONDENSATION TO PUDDLE INSIDE THE PIPE CAUSING A
COMPLETE RESTRICTION.
Posted on Mar 31, 2008
We cleaned our unit out and then my son pushed it back into the narrow area and the unit worked better but still not as it should, so we ran it that way and then pulled it out again and found the after pulling the unit back out from when my son put it in small area the Exhuast pipe pipe got crinkled very bad and was stopping the airflow. We cleaned it out throughly, I check Temp- on the back wall exhaust heat in the drum and the temp was 381 Degrees then going out the Lint boot it was 184 degrees and down on the blower the temp was 184 degrees when the burner was running and 138 degrees. when burner was off. temp at outside wall 176-150 degrees. I cleaned the Thermister and the temp. sensor in the exhaust pipe. with rubbering alchol, also the lint sensor. Hope these things work.
Posted on Dec 02, 2011
Kenmore elite he3 takes wat to long to dry cloths
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Apr 21, 2010 | Kenmore Elite HE4 Electric Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
2 problems with my Kenmore Elite dryer
Hello, I would be curious to know if the dryer performs the same way on "timed" dry and "auto-dry", have you tried ? Here's a tip on how you can absolutely know if you have venting issues ( and I don't necessarily mean a "clogged" vent, there are other factors too ) Disconnect the vent at the rear of the dryer and run a cycle as you normally would and observe what happens. Also if it has the flex venting on it ( whether plastic or foil type ) get rid of it, personally I will not even service a customers dryer until they agree to change it when present. I'll watch for you reply in this post if I can assist you further. Good luck. macmarkus :)
Apr 10, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer is taking a long time to dry clothes and can only use the timed dry or touch up setting.
Check the following areas to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 17, 2009 | Kenmore Elite HE4 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Takes too long to dry or keeps running when clothes are dry
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
707 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
