Question about Maytag M6D24E7A Air Conditioner
Maytag M6D24E7A is a 220V unit right? - Maytag M6D24E7A Air Conditioner
  • 308 Answers
Yes this is a 208/230 volt AC. Hope this helps.
Posted on May 15, 2010
I have wall mount maytag a/c,M6D24E7A I been use in 8 years,but yesterday start make verry bad noise look like fan go in to broke and stop,I start back today again did start but noise is same I turn off
mcdevito75 here, It sounds like the bearing in the fan motor is no good, Contact your local A/C shop, they come to your home and have them check it out for you.
Aug 20, 2010 | Maytag M6D24E7A Air Conditioner
With air condition running water is not draining. is there a weeping hole for the water to drain
Remove the ac unit from it`s shell,and take it outside and wash it out with the water hose,remove all debris from inside the unit,and the bottom of the inside of the unit,when replacing it back in the home,make sure there is enough tilt to the unit to get the unit to drain outside,not in,if this was at all helpful,please rate,thank you.
Aug 08, 2010 | Maytag M6D24E7A Air Conditioner
Model Number G2FD090S35A WHAT IS THE TON. OF THIS A-COIL?
IF THIS IS A WALL UNIT 110 VOLTAGE IT SHOULD BE 9.000 BTU
Apr 19, 2010 | Maytag M6D24E7A Air Conditioner
Cooles but will not heat
heat strip is possibly burnt out and will need to be replaced. The strip sits inside the unit right behind the evaporator coil, To access the heat strip you will need to remove the unit from its casing and place it on a level surface.. The heat strip is possibly in a metal casing and the heat strips look like the heat strips in a toaster. The assembly comes out by removal of a few phillips head screws and has an electrical disconnect plug that powers the coil. Take the coil assembly along with the model and serial number to the nearest appliance parts house for replacement part. Good Luck hope this helped you somewhat
Dave
Nov 09, 2009 | Maytag M6D24E7A Air Conditioner
Where on the unit is the air filter?
it is behind the vents the front should open so you can clean the filter
Sep 11, 2009 | Maytag M6D24E7A Air Conditioner
Maytag window ac unit
Feel the motor and see if hes hot ...... spin the fan by hand and see if it spins freely  if not the bearings have seized up.   So either rebuild the fan motor simply by replacing the bearings and oiling them and that should fix your problem.    IF the fan spins freely   OHM out the fan  and make sure there is no shorts or openings in the fan.     if your fan motor checks out good both mechanically and electrically  then your next step is to check the capacitor and control board
Oct 07, 2007 | Maytag M6D24E7A Air Conditioner
No control power
PRIMARY means INPUT(from supply side)
SECONDARY means output( to load side)
Sep 23, 2007 | Maytag M6D24E7A Air Conditioner
Maytag M6D24E7A Air Conditioner Logo
94 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
