Question about Exercise & Fitness
I need instructions for a hobby prestiege 720 awning, I cant figure out how to put it up. Thanks
    Guru:
  • 351 Answers
All I could find is their customer service email ,, admin1@hobbycaravansuk.co.uk
Please Vote !!
Posted on May 15, 2010
The awning has two rollers and is manually operated, but we can't figure out how to use it
Teresa, I will post links to videos on awning set up and use. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Use the Awning on Your RV
RV Awning Tutorial
1 How to Open RV Awning
How to Use and Maintain Camper Awning Pete RV Service Tips
May 25, 2016 | Dometic A&E and Carefree 18 Universal RV...
Motor Home Door Awning
When you press the operation switch do you hear the motor clicking or trying to operate? If not you need to determine if you have power going to and through the operation switch. These motors usually have an inline circuit breaker that will need to be located. Some of the circuit breakers automatically reset themselves and some have a small button on the side that will pop out when tripped. Once you determine that you have power to the motor and it still does not work then you more than like have a bad motor and will need to manually override the motor to bring the awning in. The awning should have a manual crank that will allow you to connect to the center eye of the operating gear and manually close the awning. I have attached the installation and operating instructions for your awning. http://67.238.126.140/pdf/3307901.011.pdf
Apr 14, 2014 | Dometic 975CQ Elite Oasis II Power Door...
We just purchased a used '99 Starcraft Field & Stream PUP. There were no instructions for setting up the awning. I need step-by-step ''how-to'' help since everything I've found says, ''raise support...
I had exact same problem on my 93 popup. I finally figured it out. First, the poles with the plastic rings slide into the poles with the metal rings. These are the vertical support poles. Next, the poles w/ plastic nipples slide into the other poles with rubber ends. When put together the poles with the nipples should be spring loaded. These spring loaded poles rest against the top of the camper and the nipples are inserted into the 3 holes of the pole that go across the front of the awning giving you rafter support. The tension from the spring should keep the pole in place against the side of the camper. The first 3 poles with the plastic rings go from the ground to the front awning pole where the nipples can slide through the plastic ring and then into the awning pole. The vertical poles can be adjusted for height by sliding them up or down and then twisting them like a screw to tighten them up and keep them in place. 2 of my 3 vertical poles will not lock when I twist them so I have to get tricky with them. The metal rings, which should now be at the ground, are there so that you can stake it down under windy conditions. I hope this wasn't too confusing but I beleive it will help you. Good luck!!!
May 14, 2009 | Sport & Outdoor - Others
Dorema awning` SOS
http://www.dorema.co.uk/awnings.html
try the above URL
Love and kisses to you also.
May 29, 2008 | Freezers
Exercise & Fitness Logo
101 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
