Question about NetGear WL |WGX102 RANGE EXTEND R Bridge
Netgear WGX102 I have a verizon router (wireless) and could not get connection in the basement. So I purchased the Netgear powerline products ---connected the wired XE102 to the wall with a direct connection to the verizon router. Plugged in the WGX102 in another room and trying to establish a connection to this WGX102 ---- it does not work...I've followed their instructions, but it does not work. Please help
  • 1 more comment
  • Anonymous Jun 08, 2008
    linksys
  • kathyspaid Jul 09, 2008
    I have the same problem, except I have a Linksys router. I configured the WGX102 with the same SSID as my router and set the WEP settings the same as my router. I also set the IP address outside the range of my DCHP range.
    When I take my laptop to the room where the WGX102 is installed (plugged in), my internet connection drops. I reconnect when I return to my office where my router and XE102 is located.
    Neatgear support has been clueless.
    Thoughts?
  • thardmanri Dec 27, 2008
    Same problem here
  • 854 Answers
1. Check the physical connections.
a. Connect the XE102 using an Ethernet cable into the modem or router.
b. Plug-in the XE102 and WGX102 into the power outlet.
2. Reset WGX102 device.
a. Please push the reset button in the WGX102 using paper clip and release after 30 seconds.
b. Unplug the WGX102 for 10 seconds and then plug it back in.
3. Set Static IP address on the wireless laptop
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Wireless Network Connection and click on Properties.
d. Scroll down to Internet Protocol TCP/IP and click on Properties.
e. Change the option Obtain an IP address automatically to Use the following IP address and enter the following:
IP: 192.168.0.5
Subnet Mask: 255.255.255.0
f. Click on Ok button and close Local Area Connection properties.
4. Connect wireless laptop to the WGX102.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select NETGEAR and click on Connect
f. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select NETGEAR and click on Connect.
5. Access WGX102 Web-based utility.
a. Please open any web browser like Internet Explorer or Mozilla Firefox.
b. Connect to the router by typing http://192.168.0.101 in the address field and click Enter or Return key.
c. For security reasons, the WGX102 has its own user name and password. When prompted, enter admin for the user name and password for the password, both in lower case letters.
6. Change WGX102 Mode
a. Click on AP/router mode under setup.
b. Select the option Router (access point + NAT router) under operating mode then click Apply.
7. Configure wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name. Make sure that Broadcast name is Enabled.
c. Mode set it to G and B and Channel should be 6.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter 10 digit numbers.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
8. Set the wireless laptop back to dynamic IP address.
e. Check the option Obtain an IP address automatically and Obtain DNS address automatically.
9. Connect wireless computer to the router.
Connect wireless using Windows XP Service Pack 1.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
Connect wireless using Windows XP Service Pack 2.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
From the above configuration please check if you are now able to go online wireless using the WGX102.
Posted on May 02, 2009
Hi I have 2 XAV2001 that I installed in February -- one in my home office and one in my basement. The house is new with new electrical wiring and fuseboxes. The connection worked well in the beginning...
This is a problem with Powerline devices. Its a sort of hardware problem with the Powerline devices
Suggest you to get it replaced from Netgear as its under warranty.(1 yr warranty) Call 1-888-NETGEAR and ask them give RMA(Return manufaturer Authorization) for this device. They will test your device and provide you replacement Just tell them Powerline device doesn't work at all for RMA.
Hope this helps, as there is no other way to diagnose this Device
Jul 05, 2011 | NetGear XAV2001 (XAV2001100NAS) Network...
I have LG BD370, purchased a Netgear Wireless WNR2000 N-router, As recommended in the manual, I purchased a (Linksys Cisco Powerline AV Network kit model PLK300. That was connected w/ Cat 6 cables. Have...
Get a Wireless Access Point ($30-$50 average). A wire from WAP to the Blu-Ray player should work like a charm. The WAP pretty much takes your wireless connection and transforms it back to a wired Ethernet connection for devices like this. You can have your Wireless Router on one side of your house and the WAP on the other, right next to your blu-ray player with a short Ethernet connection between the two. The player will just see it as a standard Ethernet connection.
Aug 07, 2010 | LG BD370 BLU RAY PLAYER
Netgear WGX102 Powerline HomePlug wireless ethernet bridge dead
My friend, reward your year of hard work with a new router. Yours is dead.
Dec 11, 2009 | NetGear WL |WGX102 RANGE EXTEND R Bridge
Verizon modem/router and Netgear WGR614v9 On Demand setup
  • the modem and router must connected
  • either you use a long ethernet cable to connect the tv to the router or use a powerline to extend the router.
Jul 31, 2009 | Actiontec (GT704WG) Router
I can not remember the IP address for WGX102 Range Extender
run ipconfig/all on a PC connected to the router. The default gateway usually is the router's IP.
Jul 09, 2009 | NetGear WGXB102 Wireless Range Extender...
Netgear WGX102 stops working after some usage
As the device works fine when connected in the same room. the issue does not seem to be with the powerline adapters but with the powerline itself.
If you still suspect the powerline adapter to be faulty then try connecting another powerline adapter at the same place and check if it works. This will help you for a speedy resolution
Jun 12, 2009 | NetGear WGX102 Repeater
Can't Connect to Netgear Range Extender Kit
-- you can connect the Xe102 to he wall plug where ur router is placed
-- And then reset it from the reset hole on the back of the Xe102
-- and after that connect the WGX102 to the other wall plug where u wanna get wireless access ..
-- And then reset it from the reset hole on the back of the WGX102 as well
-- And once u do that it will not ask for a security key .
-- It will show netgear unsecured
-- try to connect with it and u will be connected
Feb 14, 2009 | NetGear WGX102 54 Mbps Wall-Plugged...
Wireless Router Advice
what kind do you have right now? verizon fios offers some great wireless routers that are very strong
Dec 06, 2008 | Computers & Internet
Netgear xe102 isnot picking up an ip address
-- Xe102 is a plug n play powerline device
-- there is no specific configuration required for that .
-- try hard resetting from the reset hole on the back of the device
-- then get the powerline checked
-- check the light status of the powerline device.
And if the problem still persists , upgrade the powerline device ..
Follow the link below ::
http://kb.netgear.com/app/answers/detail/a_id/901
Nov 15, 2008 | NetGear XE102 Powerline Ethernet Adapter...
Problem
so you have 3 lights on the front panel power homeplug/internet wireless so whats the status of those lights ? do you have the unit plugged into a power extension cord - as this can cause problems are you using as a router or an extender ? download and install this software - it will detect all wireless signals - the SSID, channels and if secure
Sep 23, 2006 | NetGear WGX102 Repeater
NetGear WL |WGX102 RANGE EXTEND R Bridge Logo
1,052 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
