Question about Frigidaire FEB27S5A Electric Single Oven
My simfer built in oven wont work the built in grill works but not the oven , any suggestions please
Using grill and everything tripped now grill or oven wont work
Electric grill most often uses heater element to heat up.Maybe your heater elemen is shorted to oven body thus tripping the safety device.
Check your grill system using insulation tester.If the insulation is low check the heater elemen insulation and if defective replace them.
Jun 17, 2012 | Zanussi ZBF360 Electric Single Oven
Grill not working after replacement element - any ideas?
I would say you are right on your wondering. look at your manuel and it will show you a diagram
May 07, 2012 | Zanussi ZHQ575 Electric Double Oven
My grill uses the same elemant as my grill but grill wont work , but oven will
when you use your grill the oven door must be open if if does not heat then the door switch is faulty
Apr 21, 2012 | Ovens
Wont get hot grill works think the element has
If it is a fan assisted oven, then it is probably the oven element that has failed.
This is usually located at the rear of the inner oven compartment behind a removeable panel
May 04, 2010 | Ovens
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Help!!!!!!!!
Sounds like the oven element is faulty.
This is usually located at the rear of the oven compartment behind a remov eable cover.
Please rate my solution.
Thankyou
Jan 25, 2010 | Ovens
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Creda cooker grill not working,elements replaced, still not working. any suggestions?
Could possibly be grill selector switch faulty, or, depending on the model, it is sometimes caused by a faulty main oven door switch.
Thanks.
Jul 29, 2009 | Ovens
Frigidaire FEB27S5A Electric Single Oven Logo
191 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
