Question about Miele H187MBALU Convection/Microwave Oven
No power we hard wired it, and it does not work
I recently removed a faulty microwave from a wall cavity unit under the oven that had not been working for a year that i was aware of and still plugged into the mains and switched on with no power to
If you are talking about a normal plug in situation, then I would say just go ahead and unplug it and that will remove any risk of shock or fire. If you are talking about it being hard-wired and it is on the same circuit as the oven, then that is another story and I would suggest getting someone that can work with electricity if you are not comfortable with it and have it disconnected from the line and the wires tapped off so that they will not cause any problems and then your problem is taken care of. If it is on a separate circuit you could just turn the circuit off and put a piece of tape over it so that it does not get turned back on. Hope this helps!
Feb 11, 2015 | In Microwave Ovens
Mcd 1311st blowing circuit breaker
Generally microwaves should be on their own breaker. Hard wired ones are required to be by code.
If yours has a plug - make sure the plug is original with the unit, not added later or spliced onto hard-wired power leads.
Plug into and outlet rated 15A as the only thing on a 15A branch circuit and try again. If it still trips, try a 20A line and circuit. If it trips that, trash the microwave and buy a new one. Nothing is meant to be repaired inside.
Nov 03, 2017 | Microwave Ovens
Kenmore microwave 721.62642200 bottom lights do not work no voltage at connection
HELLO.
It is obvious that there is no electric power supply in your microwave oven.
The problem of your microvave is likely to be from the fuse or wiring connection connected to the panel.
What you need to do fix up the problem from easy to hard , first of all is to carefully unplugged the plug from the wall then allow it to relax for some time then plug it back again to the power supply correctly to see if the problem will be solve ,
Then take a look on the fuse and also the wiring mention above the fuse is some time located at the tip or the mouth of the plug depending on the type of the wiring connection on the oven or inside the oven it self which will need to be check on and same condition is apply on the wire as well.
Please get back to me for further instruction if necessary.
Thanks.
Sep 18, 2011 | Microwave Ovens
I have an NEC N920E Microwave. The turntable no longer turns. I am a licenced electrician - can I fix it?
Sure you can fix it. The turn table just have a small motor inside and some gears. Remove it and check the motor for contitunity and also check if the wire leads getting power when the oven is on. Most of the time the motor is hard to repair and not worth your time so it is best to replace it, it has enamelled wires as thin as human hairs. lol
May 28, 2011 | Microwave Ovens
Microwave is humming when off display says F6
We had a power failure for 2+ hours. I went to defrost something when the power came back on. Somewhere along the line the F6 popped up. With the door closed it sounded like the machine was running.
I slapped the side too and it worked. I pulled the vent cover off to clean it and found the tech sheet stuffed in a bag inside. I found what F6 means. 'Microwave relay failure. Check wiring to relay 4903 for short circuits. If wiring is ok, replace control board' Then, of course, a whack on the side by the button panel worked
just as well. rek('_tx6');
Reference: It means the relay is stuck in the run position. Apparently if you slap the unit hard enough it will unstick the relay and allow it to work properly again. rek('_tx7');
Aug 06, 2010 | Kenmore Microwave Ovens
Lights under micro do not turn off all of the time but some of the time. Finger sensitive pad does not register 0, 7, 8.; most of the time.
sounds like your touch pad is bad. if its under a year old. call for warranty service.if not you may need to order a touch pad. its not too hard to replace. remove power, take tho screws off the top of the micro holding the top vent cover on. remove the vent cover. above the touch pad is a screw, remove that screw and lift the Assembly up and it will tip out. be careful because you don't want to damage any wires. you can label and disconnect the wires to completely remove the Assembly.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 18, 2010 | Samsung Microwave Ovens
Lg ka60510f not heating although everything is on
Find the circuit breakers for the unit, it should be a double breaker with at least 30 Amp rating. Push it to the off position HARD (make sure not to pull the breaker out of the panel doing that). Turn it back on. Check voltage in the range power outlet. It should measure 220-250 Volts between the right and left connectors, and 110-125 Volts between the center and each side connectors. If not - problem is in the wiring or breaker. If you get those voltages and the range is still not working - problem is in the cooktop itself. Disassemble and check for shorted and loose wires.
Dec 18, 2009 | Microwave Ovens
Does the rf375pxdw whirlpool range have a fuse or reset button? burners and oven does not work. there is power from the 220 plug into the range and the clock operates but not the 220. I checked circuit...
No reset buttons or fuses. Find the circuit breakers for the unit, it should be a double breaker with at least 40 Amp rating. Push it to the off position HARD (make sure not to pull the breaker out of the panel doing that). Turn it back on. Check voltage in the range power outlet. It should measure 220-250 Volts between the right and left connectors, and 110-125 Volts between the center and each side connectors. If not - problem is in the wiring or breaker. If you get those voltages and the range is still not working - problem is in the range itself. Check for shorted and loose wires.
Kenmore Microwave Oven Sudden Power Reduction
I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady, I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84 here.
Feb 14, 2009 | Kenmore 62622 Microwave Oven
Miele H187MBALU Convection/Microwave Oven Logo
Top Miele Microwave Ovens Experts
William Miller
William Miller
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
