Question about Dishwashers
Machine stopped and water in base of dishwasher
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
Dishwashermachine stopped and water in base of dishwasher - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 15, 2010
What is aquastop
I presume that when you say it wont stop running, it's the empty pump that is running. This is an anti flood protection. Water from a spill has got into the base of the machine and tripped the flood protection sensor. To cure the immediate problem, pull the machine out and tip it on it's side or back about 45 degrees and the water in the base will run out and the flood protection will reset. The real question is though, how did the water get INTO the base? Most common is that someone used household detergent instead of dishwasher powder or tabs and the foam it created worked its way into the base and then turned back to water as it settled. If this is the case, the tip sideways will be a permanent fix. If not, you will need to trace and cure the leak
Sep 23, 2015 | Bosch Dishwashers
Have a bosch dishwasher Mod. No. SGI53A55AUSS installed March 2004. All filters clear, exit pump clear and working. Switch on washer can hear exit pump working but machine does not accept water to fill....
You said you had water under the dishwasher,did you remove the lower panel below the door and check for water in the base frame as well. Bosch dishwashers have system in the base frame that detects water in base and cuts power off to every component except drain pump till it no longer sees the water in the base.
Hope this helps
Gene
Aug 03, 2011 | Bosch Dishwashers
When turning on dishwasher it just fills the base with water, tried manually draining and pressing reset buttons to no avail
Most dishwashers kick on a valve to fill with water.
There's a float in there somewhere that triggers the shut off to the filling water.
Once water reaches this cut off level the pump should be throwing water thru the wash arms.
If base isn't filling to capacity...Id look to the drain valve.
If it fills to capacity and stops...the pump may be out or something is obstructing it.
Hope this helps...
Jul 30, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
I know the machine can fill and drain but it stops after filling and does not proceed and drain intake light is on
sound like you have a water leak. It is fitted with a float switch in the base of the machine and if it senses water in the base then it switches off and brings the inlet/drain light on
Feb 21, 2011 | Miele Incognito G858SCVi Built-in...
Hoover HED 6612/1-80 dishwasher all four lights flash and beep whilst the machine drains, after a couple of minutes the beeping stops but the four lights glow. Cannot reset to cancel. Also still makes...
Not sure if you have got a user manual for this dishwasher. You can download one from this site.
You have a flood situation inside the dishwasher. See page 12 of the manual. There may be no water at the bottom of the machine but there is some overfill occuring. Also see error codes on page 13. This can be either because the flood detection circuit is faulty and giving false trigger or there is water in the base of the dishwasher housing due to leaking door gasket or hoses.
Some things to try. Turn mains power off and back on and see if there is any difference.
If not, then turn power off and pull dishwasher out from the kitchen benchtop. Put a few towels on the floor and tilt the dishwasher side to side on the base and see if any water comes out. Wait 5-6 minutes and turn power back on. See if it makes any difference.
Dec 15, 2010 | Hoover Dishwashers
Need a service person. Machine reads F1 and must unplug to stop it from running
Is this happening with both drawers or just one.
You have water leaking into the base of the dishwasher under the drawer.
Most likely the drawer seal is leaking.
The flood switch is located at the base of the dishwasher and this needs to be dried.
Turn power off and take the bottom drawer out. Dry base with towels and hair dryer. Turn power back on without putting the drawer back.
Run top drawer to see if any water is leaking.
Water leaks can be due to faulty seal or drain hoses cracked.
Hope you are able to fix it.
Sep 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The machine stopped with 33 minutes remaining on 96. There is a "pumping" sound but no water comes in. The dial says it is on rinse but it does not rinse. Bosch Dishwasher EN: SHU4326UC/U12 FD8007. 260415...
If you have water filling up in the sump, you will get that scenario. If water is out of the tub, pull unit out and tilt backwards about 45 degrees. If water comes out from the base(sump), then you know you have a leak and need to have it attended to. Note, if water does come out when tilting the machine backwards, you will find it will work again until base is full again.(Switch off before tilting the machine backwards just for safety.
Jul 21, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Error code e4
This might be a re-badged generic dishwasher - on my Baumatic E4 error caused by floatswitch in bottom catch tray. Some (supposedly small amount) water collects here and should evaporate naturally. If it accumulates, float rises and stops machine.
TURN OFF THE POWER
try to find a way into the machine base catch-tray to sponge it out - on the Baumatic there are two large black plastic plugs on the front of the machine base that can be forcibly flipped out.
failing that, take machine out and tip it up to get rid of water
Oct 09, 2008 | Maytag Dishwashers
Dishwasher sounds like it is working!! But no water is getting to the machine. It was working fine then one day just stopped.
could be inlet valve or in flood mode check to see if water in base of dishwasher(underneath)hope this helps i dont know what make or model you have.
Mar 14, 2008 | Dishwashers
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
