Question about Refrigerators
GE Side by Side Water Dispenser not working
Dribble of water comes out and then stops. Nothing.
  • 109 Answers
Check your water filter first, second loosen the water line to verify you have sufficient water coming in to unit, third replace water valve.
Posted on Mar 30, 2008
SOURCE:
Inside water dispenser pumps water out really slowly on GE Profile PFS22MISBBB
It is possible that your water filters are getting plugged. Have you changed any filters lately?
The meat pan lever may also be turned to the coldest position and on units that have a low water usage, this will also cause the tank to freeze. You will want to lower the meat drawer setting or use more water from the door. This does not apply to Top Mount water dispenser models, because they do not have a reservoir. Problem requiring service, glass fill time.
View a short video about troubleshooting water dispenser issues :
Play Video
View a short video about slow water dispensing issues:
Play Video
  • Dispenser drips water constantly will be a water valve problem, and should be checked by a service technician. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
  • Dribble as defined as a small amount of water (few drops) that may miss the glass ONLY AFTER USAGE. This is due to a delay in the overall system.
    Dribble can be minimized by the following actions:
    - Purge the tank, by holding down the dispenser for 2 to 3 minutes, to remove any trapped air that may be building pressure and causing the dribble.
    - A few drops is normal, but you can also prevent water from missing the glass and dripping down the cradle area by moving glass slower when removing it from the cradle.
    - You may need to periodically empty the recess grill and clean out underneath it to prevent overfilling and water dripping down the front of the refrigerator.
  • Also, remember the dispenser in the door will not operate unless the door is closed
  • Apr 10, 2012 | GE Refrigerators
    The water dispenser stopped working. It makes a sound but nothing comes out. The ice dispenser works fine.
    You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don't hear it there is a dispenser actuator switch problem. If you do hear it but water doesn't work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
    Nov 03, 2010 | GE GSS20IEM Side by Side Refrigerator
    Water dispenser stopped working. Water valve works
    A major problem with the ge side by side refrigerators with metal liners is water freeze-up inside the door of the freezer. Short term repair is to heat the dispenser area CAREFULLY with a hair dryer right at the point where the water spout comes out.
    The long term fix involves installing a heater in the dispenser part number wr49x10173 @$60. The kit comes with installation instructions..
    Let me know if you have any questions!!
    Aug 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
    Water at door stopped working. water still comes to ice maker. no damage to electronics panel. Ice dispenser, whole and crushed works fine. is there a relay in the water circuit that fails? Or, is a...
    I have the exact same problem. Ice maker works but nothing at the water dispenser. The light come on when I press the lever and I hear a click. But nothing like water "trying" to be pumped. I am nervous it is more than just a frozen water line. Anyone else have this problem or a solution?
    Dec 09, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
    Water feature does not work
    Unplug the female connector on tear of refrigerator on the side that feed the dispenser control. With a voltage meter place the 2 probes while some presses the dispense water control. You should get 120 volts there when the dispenser switch. Thanks Sea Breeze
    Nov 16, 2009 | GE GSS25SGPSS Side by Side Refrigerator
    GE PFSS6SMX french door fridge water dispenser not working
    check the fiting where you tapped the water for the uit. If its a saddle valve what happens is the the gasket closes down and restricts the water flow.
    Feb 28, 2009 | Whirlpool GD2SHGX Refrigerator
    Water dispenser does not work
    most likely the water line for the dispenser has frozen in one of 2 places. the first place to check and the easiest is the water tank behind the crisper drawers in the fresh food compartment. what i would do is use a hair dryer to warm the tanke and see if it will start working again. the next place that is common for it to freeze is in the freezer door. the only way to fix this is to leave the door open for a while to allow it to thaw out.
    If I'm not mistaken I think there is a recall for some of the  GE sxs refrig that addresses the water line freezing in the door. you may want to all GE and heck on that. good luck peyton
    Jan 27, 2009 | GE GSS25LGM Side by Side Refrigerator
    Water only dribbles from the water dispenser
    It sounds like you have a clog. If the clog is at the nozzle, you would still have pressure, however nothing would come out. It could also be the valve that opens for the dispenser.
    Take it apart and look. I would focus on the dispenser end.
    Dec 05, 2007 | Whirlpool ED2FHEXN Side by Side...
    Ice maker not working
    So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
    Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
    Refrigerators Logo
    78 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Marvin
    Marvin
