Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
My whirlpool duet sport washer will turn on, meaning the power button lights up lights on front, but when I push start, all lights go out and it shuts off
  • prem mathew May 27, 2010
    Go the search bar above, type your make & model number
    to search. When a page appears, scroll down a bit - check
    out the solved problems to find similar
    ones to yours. Possible you will find some or you
    can click on ‘Manuals & How-To s”
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$##
Posted on Sep 30, 2010
Whirlpool Duet front load washer
If you push the end of cycle button for 5-6 secs. It turns the control lock on, do it again, and it turns the control lock off, on both the washer and the dryer
Mar 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset a whirlpool duet washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washer power button problem. I have to push power button a 10-15 times and the power will be on. Please help.
pushing the button that many time is not the problem on this type of unit you push the start and hold of about 5 sec's then you'll hear the unit start door lock and oper through a normal cyc a word of advice don't close the door very hard push into place these things are plastic and will break the latch assy then will cost $$$ for parts good luck
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer will not start.
if you want to replace your washer you need to talk to lowe's store manager nobody else he or she will replace your unit. other wise you call for service. i think your washer need new main control board. good luck.
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Control lock light is on , washer won't start
your controll is in child lock turnning power off wont fix find the lock button and push hold till light goes out
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
