Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
I have a toshiba projection screen 51HX83. Works great except out of the blue the sound stopped working. Is just over 6 yrs old. Any ideas?
  • Toshiba Master
  • 19,396 Answers
Hi.
Disconnect the TV from power for a couple of minutes. This will reset the set.
If you are using an external tuner or a DVD connected to the TV, check the connection cables.
Test the TV using different cables and connections.
If that does not work, then parts that must be tested are terminal circuit (input/output connectors), audio board, and connection to speaker.
If there is an home theater connected, then the problem can be the home theater. Test using the TV speakers.
If you get rid of the audio problem by connecting external speakers or using headphones, then problem is the connection to TV internal speakers.
Here all parts for your TV model.
Regards.
Ginko.
Posted on May 15, 2010
Need to replace screen
Not sure where you will buy the screen for it and shipping will be pricey. There are going to be a couple pieces of plastic you need for the screen. Make sure you get the right ones.
Dec 30, 2012 | Toshiba 51HX83 51" Rear Projection...
Toshiba 51HX83... what kind of lamp/bulbs and what size do i need to bring the brightness back?
your model doesnt have a lamp it has three CRT (Picture tubes) often just cleaning the rear mirror will restore brightness. If that doesnt do it then the CRT coolant may need to be replaced.
Aug 06, 2012 | Toshiba 51HX83 51" Rear Projection...
Toshiba 43AX60: sound but no picture
try switching to a different video source and play a DVD or a game system. If the issue is still there try unplugging the TV for 5 min. and then plug it back in.If the problem works fine on all other devices except the video source that has the issue try hooking up the same device your having the issue with to a video source you know works if that works then you have a bad video source on the back of the TV, if it does not work it's either the cable going to the TV or the device itself.
Jul 08, 2009 | Toshiba 43H70 43" Rear Projection...
Sound is out for all inputs on Toshiba 51HX83
There is a switch on the back of the TV for center input. Make sure you have this set to OFF.
Oct 12, 2008 | Toshiba 51HX83 51" Rear Projection...
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
Toshiba cf35f50
You are missing the red color drive or it is weak. there are adjustments for that in the service menu or on the CRT drive board, but you should not attempt these adjustments unless you have a service manual or know 100% what your doing and how to do them. it could be the picture tube is weak or there could be a problem in the RGB drive circuits. Depending on how old the set is should determine or not it would be worth dropping any cash into it Good Luck
Mar 20, 2007 | Toshiba CF35F50 TV
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
