Question about Umax Astra 6700 Flatbed Scanner
Scanner usb port connector did not detect properly
Please suggest me
DR-9080c Isn't being detected via USB
Uninstall the device driver, restart the Comp and reinstall the software. If the scanner is not detected, try inserting any working device on the same USB port. if it detected, thee could be problem in the Scanner, if the new device is not detected, then it may be port problem.
S. Mohan, India
Feb 07, 2013 | Canon DR-9080C Path-Through Scanner
Have downloaded a driver for mustek 600cu but still not recognising scanner
First install software driver if finish, connect your scanner USB cable to USB ports of CPU(make sure that your USB ports working good, test also using your USB flash drive).then you can see on screen automatic detect your scanner. if not detected try to change your USB scanner data cable. then try again connect to USB ports of CPU.
Just let me know if not yet working.
Thanks for using Fixya.
Jul 13, 2011 | Mustek Plug-n-Scan 600 Flatbed Scanner
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
My Lacie was working fine till I brutally unplugged it from usb port when I about to go home from office. After I go home, I plugged it to my home computer, it cannot be detected any more. Next day I...
Please take the Hard disc to a technician for a soldering repair job.
It happens in many cases, that after brutally unplugging the drive the connector connecting the drive to the board of the hard drive gets loose... or the connections break which does not let the hard disc being detected.
A repair job will fix the issue for you for sure.
May 20, 2010 | Computers & Internet
I DON'T KNOW WHERE TO PUT THE USB CONNECTOR
If you only have one USB connector then you can purchase an USB hub which may have 4 or more ports (I suggest you get a powered USB hub). Then plug the hub into the computer's USB port and you now have several USB ports.
Jan 04, 2010 | Canon CanoScan 4400F Flatbed Scanner
I can't use my Umax Astra 1220S scanner in Windowa XP
uninstall the all scanner driver have you installed then connect the scanner to your pc and switch on the scanner and check it detecting the scanner or what ..... if its detecting install the scanner driver ( or go to control panel ..>scanner and cameras open it then click i add device and fallow the steps ) ..... if its not detecting the scanner its may have the problem with the scanner connector or may with your pc usb port ...............
Dec 31, 2009 | Umax Office Equipment & Supplies
My front USB port do not detect nothing.so i use the back USB port of the CPU.my collegue has complained that his pendrive has been damage by the front USB port.is this true?
This is only true if the wires connecting the front USB port to the motherboard are connected incorrectly.There are 2 pairs of wires for each connector: one for the +5V & -5V (power) & the other one for the signal itself. If those are not connected properly, the power connectors could be connected to the signal, in which case if a device is connected to the port it will get damaged.
To connect those connectors properly, you have to refer back to your motherboard's manual.
Nov 16, 2009 | Intel Motherboard
The scanner(travelscan pro 600) gets a no power or not connected message!
Go to Device Manager and most likely the travelscan pro 600 is not popping up under imaging devices where it should be. Unplug the scanner and plug it into a different USB port. Try this on all the USB Ports on the machine if it reappears in device manager then the software will work. If you are using a USB extention cord or USB hub get rid of them till you try all the ports. If it doesn't i would suggest contacting the manufacture and seeing if the scanner is still under warranty.
Apr 17, 2009 | Ambir Technology TravelScan Pro 600
Proper plug for laserjet printer into my HP 761n desktop
unplug all the connection again.
plug in one item at a time, and wait till the computer finished the detection. If the computer can't detect the USB. try another USB port. till all of you devices are connected.
Apr 09, 2009 | HP Computers & Internet
Scanner
THE PROPER WAY ON INSTALLING USB DEVICES A. Enable usb ports on the BIOS. 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 21, 2007 | Microtek ScanMaker 4900 Flatbed Scanner
Umax Astra 6700 Flatbed Scanner Logo
32 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
