Question about Refrigerators
My kenmore fridge mod# 59662822200 will not keep cold
My kenmore fridge mod# 59662822200 will not keep the fridge part cold but the freezer is working fine where should i start looking for problems. We have cleaned it, moved the tstat setting up and down with no luck
  • 1,557 Answers
You need to test the defrosting element in most cases this is the problem either that (most common or the defrost timer (least common or the frezzer fan ( secound least common in most cases its the defrost element it does not defrost the air flow tubes leading to the fridge compartment thus the cold air cant get through
good luck
Posted on May 15, 2010
Model # 59673509201 suddenly the freezer defrosted, but is running both the fridge and freezer are cold what happened? should i have both set on colder.
Kristina: I am guessing it automatically defrosted. As long as the freezer and refrigerator work... keep setting to keep cold but not freeze stuff in refrigerator.
May 10, 2015 | Kenmore Refrigerators
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
Fridge not working freezer works what should i do
see if you can hear the evaporator fan running in the freezer. if you can't you will need to replace it as this fan pushes the cold air from the freezer into the fridge to keep it cold.
Nov 07, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
21' bottom freezer kenmore refrigerator-no ice maker-the fridge is super cold and freezes all my vegetables and fruit. We have cleaned the coils, cleaned the fridge, and it just keeps freezing. Fridge is...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 02, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
New fridg won't blow cold air
MOD. NO. MBF2255KEW
The freezer is working but the fridg is hot any help will be app.
steveavans1@hotmail.com
Jun 22, 2009 | Frigidaire FRT21HS6D Top Freezer...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Refrigerators Logo
246 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
