My laptop screen turns black when the windows loads.. its connected to an external monitor that i tested on other pc and it was fine the problem in my laptop it runs only on vga mode and safe mode any solutions??
  • mohamadoz May 16, 2010
    of course i know how to do that :D:D
    but the resolution thing didnt work out
    when i change the resolution to more than 640 x 480 screen turns black.
    it used to work fine on 1280x800 but suddenly it didnt work at all..
  • mohamadoz May 18, 2010
    ok i fixed it by installing a new windows
    it was some sort of a virus bec. later i found out that i file in the system was missing and the windows couldnt start up at all.
    any way thanks for ur help :D:D
  • 4,737 Answers
Try changing the resolution settings, this will solve your problem. I hope you know how to do this. If there's problem, let me know..
Posted on May 15, 2010
  • Lebanon Raingam
    Lebanon Raingam May 18, 2010
    It's good that you've done it yourself, i also thank you for being responsive.. good luck again..
White screen
First see if the power on self-test (Fn+ Power) or the LCD BIST (D+Power) will run. The Diags are normally on a blue screen with white test, the LCD BIST is simply 4 Solid Color Screen looking for defects in the LCD panel.
If you hear beeps/windows sounds when the system boots and the LCD BIST test does nothing then the LCD has likely failed and you will need a new one. You can try an external monitor and see if you get video on an external screen.
If you don't then try these steps:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jul 17, 2011 | Dell Inspiron 1545 Notebook
When I start up my Coby netbook the screen in black. However I can hear windows loading. What can I do?
Does your netbook have a vga out? If it does then try testing your netbook by connecting it to a compatible external monitor by connecting a vga cable. If you see youre regular boot up in the external monitor (because you said that you can hear your netbook boot and i pressume that it is windows that you are hearing) then theres something wrong with your netbooks monitor.
Have it checked by a proffesional.
Jun 29, 2011 | Coby NBPC1023XPPNK Netbook
Laptop Monitor Problem - I have a Toshiba Satellite Laptop. I had a system crash and I think I may have had a second problem with my monitor on my laptop showing, it went black and flickers on and off. ...
Possible disconnect of the wiring harness from the LCD to the motherboard? Might just need a new screen, but always check the simplest first. Flickering may imply faulty wiring or a lose connection in my opinion.
Mar 02, 2011 | Toshiba Satellite A135-S4467 Notebook
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is...
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
No display everything turns on windows loads but no display
We can further isolate the issue by connecting an external monitor to the notebook. If the display is fine with the external monitor, this clearly indicates that the issue is related to the LCD screen. Otherwise, it is due to the some other internal hardware.
You may follow these steps to connect the notebook to an external monitor.
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
External monitor.
May 14, 2010 | HP Pavilion DV9620US Notebook
Hello, I have a problem with hp pavilion dv
Try lowering your display settings when it is hooked up to the external monitor. Then try the laptop screen again.
Right click an open area of the desktop, select properties, click the display tab. In the lower left of the box there is a settings slider, try lowering the settings and see if it gets better.
Dec 13, 2009 | HP Pavilion dv6000z Notebook
Screen on laptop keeps going black
please explain further. keeps going black from where? after turning on the laptop? of after windows logo? if after windows logo screen turns black if a no boot issue where laptop cannot load system files. if screen is black after turning on no manufacturer logo and windows logo or anything then it might be the LCD or video card / motherboard. to isolate try connecting your laptop to an external monitor and check if you will be getting the same problem. if no display from the external monitor then its a video card issue, if video card is integrated needs to replace motherboard.
Oct 01, 2009 | Computers & Internet
Monitor does not work, computer starts up, dell prompts load, windows prompts load then screen goes black. i can hear everything loading but no display.
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Gateway laptop 450 rog
be sure to circle through possible screen.
use FN key + a key with a screen symbol on your keyboard (or check your doc) to switch from main screen to external monitor and back.
sometime some techies use external monitor for pc final test and forgot to restore configuration to laptop screen.
At restart XP is expecting the last used monitor and nothing shows on laptop screen.
try also connecting any external monitor to vga plug.
let me know if is fixing
Jan 04, 2009 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
