Question about Aquabot Pool Rover Above Ground Robotic Pool Cleaner
Online instruciton manual
Would you know if there is an online version of the aquabot pool instruction guide? We seem to have misplaced a few pages:(
thank you
Allison
    Guru:
  • 351 Answers
Here is a page of articles from aquabot ,, lots of instructions you can view ..
http://www.123aquabot.com/Articles.htm
Please Vote !!
Posted on May 15, 2010
Testimonial: "took me right to what I needed and with trouble shooting site. Thank you"
The aquabot doesn"t go all
If you can wiggle the cord and make the pool cleaner work, it sounds like an electrical problem. If this is the case, you need to have it serviced by a professional. There are a few things you can check first, though. Make sure that the filter bag is clean and clear of debris. Make sure that all lint, cloth, or debris is removed from the impeller.
Sep 10, 2011 | Aquabot Pool Rover Above Ground Robotic...
Aquabot T4 RC, Pump runs for 1 second then shuts off for 4 seconds, then repeats its self.
Mine does this too some times. I find that if i manually force the wheels (out of water) to turn slightly and then put it back in the water it works again for a bit. I think something is jamming it but can not find out what the issue is. Let me know if you solve it!
Jul 04, 2011 | Aquabot Turbo In Ground Pool Cleaner
Aquabot wont pump or move, intermmittent
Well either you have a jammed up motor, or a bad motor, or the Controller unit has faulted.
http://www.robotshop.ca/PDF/aquabot-turbo-t2-manual.pdf
Above is a manual, this should help you it has exploded diagrams to help. There seem to be many ways that it could get tangled up, or maybe the belt has come off, any way it's about time to A: Get a screwdriver, or B: Call a service man....
Jun 01, 2010 | Aquabot Aquaproducts Automatic Swimming...
How do I change the driving belts on the side?
http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ will be a definite aid. Also, Aquaquality Pool Supply includes instructions with their replacement belt sets, or, if you are near Phoenix Az I will help you install your replacement drive belts, S. Christian dansker01@msn.com
Aug 03, 2009 | Aquabot In - Ground Robotic Pool Cleaner
Keeps tipping over
With these automatic pool cleaners, this is often a problem with the treads or having air in the head. Make sure that your treads are not worn and are getting proper traction. If they are worn, you might need to replace. To rid the air, try turning the Aquabot upside down and submerse in the pool for a few minutes. This should force the air out.
Jul 12, 2009 | Aquabot In - Ground Robotic Pool Cleaner
Aquabot is pushing out water but will not move to clean the pool
I am not sure if this is the manual that you are looking for, or not, but just in case. If you following the link below it will take to you the T2 User's Guide, with the trouble shooting.
http://www.i-love-my-aquabot-automatic-pool-cleaner.com/support-files/aquabot-turbo-t2-manual.pdf
According to the trouble shooting guide:
Pumps Water, but Does Not Move or Moves Slowly
1. Remove any foreign matter that may be obstructing Drive Tracks.
2. Check Drive Belts and Tracks. Make sure they have not slipped out of place and that they're not loose.
3. Observe Drive Pulley, if it is not moving contact Customer Service.
Jul 05, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
What is "C-RUN" on the control module?
C-Run stands for "Continuous Run" which allows the Aquabot to operate for a long, long, long enough time to get evrery nook and cranny of your pool (barring its bag from getting so clogged with leaves, dirt or D.E. filtration particles that it can't operate well).
Jun 07, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot Turbo T won't climb
1.`. Replace your old, water logged floats. They will dry out when the unit is out of the pool, and the unit will work fine until they water log again, which may takes as few as 10 minutes in the pool. 2. Stop using all those words *********** didn't teach you and probably didn't even know...This is a common problem. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ gives some really good insight, too! S. Christian dansker01@msn.com.
May 11, 2009 | Aquabot Turbo T
Aquabot T2 moving in circle
The T2 has one set of belts and a single drive motor. Since one side must be rotating to be moving in a circle, we can then assume that the motor and belts are not the issue here. The two halves of the brushes are connected by a mechanism that allows them to turn independently of the other half. They can rotate about 3 times before they “lock” and act as it were one (not split) brush. This “slippage” is how the cleaner turns. Make sure that they do lock by manually rotating one side. If not, you will need new brush/wheel tubes.
A parts diagram can be found here:
Aquabot Parts and Repair
Jan 09, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot Pool Rover Above Ground Robotic Pool Cleaner Logo
1,455 people viewed this question
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
