Question about Gaggia 90901 Platinum Swing Up Automatic with Milk Island Platinum Espresso Machine
My coffee maker is prebrewing but then does not dispense coffee
  • 952 Answers
Thanks for using FixYa.
The lines inside are probably clogged already. You might want to give your coffee maker a general cleaning by opening the top and using compressed air to clean and de-clog the lines.
I hope this helps. Thanks and good day.
HotRatchet
Posted on May 15, 2010
Why does it now stop at prebrewing and not give me coffee? I hear all the right noises...it has tamped the coffee grounds, drip some water in there, but not finish the brew. Also, the bypass doser is...
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter
Apr 12, 2011 | Gaggia Syncrony Espresso Machine
Failing to runwater through system sometimes for espresso coffee it is not prebrewing
Hi
In the menu there is a setting for pre-brewing. It needs to be turned on in the menu.
Apr 05, 2010 | Saeco Royal Professional Espresso Machine
Miele cva615 how to make coffee stronger less water
open the door and adjust slide for more grounds, also program prebrewing so it adds a little water to the ground to get them going before the rest of the water is pushed though.
Feb 28, 2009 | Miele CVA615 Espresso Machine
Cuisinart grind/brew 10 cup coffeemaker
The part the manual doesn't mention is that, after you have set the program time, you have to press the program button one more time. THEN, set it to auto-on. Also, make sure that the clock is set for AM/PM as appropriate - it will display PM if it is set for PM, and will not give an indication either way if it is set for AM.
Voila!
-Tha Mp3 Doctor
Feb 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Saeco Vienna No creme' and can't lessen amt. of water in shot
Hi
Have you taken apart the brew unit lately? If so you did not put it back together correctly. Sounds like you have lost the crystal ball or you installed the spring upside down, in the brew head.
Feb 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Hot water
Have you kept up with descaling?
Probably the water heater has failed. If you're technical then most parts should be replaceable but you may have to order them from Gaggia in Italy.
Oct 30, 2008 | Gaggia Titanium Espresso Machine
Small coffee and coffee not dispensing?
Try to program it, press and hold the small cup button. When you have enough of coffe, release the button.
Now try to make a cup of small coffee.
Hope this will help you.
Best regards
/Mirran
Aug 31, 2008 | Saeco Royal Professional Espresso Machine
When i choose which cofffee i want to make the water comes out of the nozzle and not out of the cofffee compartment.
Make sure your steam knob is closed and that your brewing unit is clean.
If you have this then it can be the electromagnet that controlls the steam or the electric board.
Jul 14, 2008 | Saeco Royal Digital Plus Coffee...
2-cup won't work
you can try descaleing it again ,then go into
the factory reset program and reset it , I had a
similar problem this fixed mine
Dec 26, 2007 | Saeco 00034 Incanto Sirius Super Automatic...
Gaggia 90901 Platinum Swing Up Automatic with Milk Island Platinum Espresso Machine Logo
83 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
