I have a Panasonic Dpc 354 copier. Its displaying a maintenance wrench that says replace fuser. Is there a way to reset that fuser code to keep the machine running until I replace the fuser.
  • 4,924 Answers
Yes it is ...you have t search in the menu ..and choose into the reset list ...it in the same location where the drum counter is reset ..but when you get there ..instead of pressing yes or no ...for reset..just use the arrows and select further in the menu until you get to what you need..reset it ..and it may work...a while ..until replaced ..
Posted on May 15, 2010
How can i reset the code error sc543 for kyocera fsc1020mfp
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Oct 02, 2014 | Kyocera Office Equipment & Supplies
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
May 09, 2011 | HP LaserJet 5550 Printer
We changed the fuser on the IBM Infoprint 40 Model #004, Type 4332. However, after changing the fuser, we still get an error code in the display that says "008 Change Fuser." What does code 008 mean? ...
008 is the printers code to tell you to replace the Maintenance Kit. IBM Part Number 90H3567. After installing it, you have to make sure to tell the printer to reset the count value for that maintenance kit.
Jun 11, 2010 | IBM Office Equipment & Supplies
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
Need to clear the error code "replace Fuser" Fuser is new and so is the paper tray cannot seem to get the darned thing to clear
Put the MFC into Maintenance Mode
Press the Menu and Start Keys at the same time then press the up arrow key 4 times the machine should display "Maintenance " in the LCD display
Press the 8 key twice, Display should show Part Replacement
Press up or down keys to select "Reset Fuser" press OK or Start Key to reset the counter of the fuser
To Exit Maintenance Mode press the 9 Key twice
I hope this helps.
Aug 20, 2009 | Brother MFC-8460N All-In-One Printer
Panasonic copier DP8530 has a E4-02 code.
hi i am working on panasonic copiers.E4-02 this code shows there is some problem in fuser unit
1.pull out side fuser unit from copier
2.check it is movig easily
3.check all gears
4.check thermostate and thermistor
5.bearings and seals
6.for to reset heater codes press function, orginal size,3.F1 will display press 9 ,06(ram initialize) sub code 04 start .fuser code will bi reset.
was it helpful .not forget to rate me .MIAN AKHLAQ
May 08, 2009 | Panasonic DP-8035 Grayscale Copier
Copier will not operate due to wrench symbol
Hi the the wrench symbol appears when its time for maintenance depending of the type of service needed the copier will shut down, the only why to over come this is to call your service provider for maintenance they will replace what ever parts and or sevice thats needs to be done, they will then enter the code that is need to reset the wrench symbol..
Good Luck
Jan 27, 2009 | Panasonic FP-7735 Black and White Copier
Epson C9100
Press and hold the four directional buttons as you turn on the power. Keep them held until the panel shows MAINTENANCE MODE. From here you will see the menu entry to reset the fuser counter
Aug 20, 2007 | Epson Aculaser C1100 Printer
22 people viewed this question
jasbo
jasbo
