Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
After a power cut the unit will not function. Previously it worked fine. It is a Tecnik Type S9J1TI dishwasher
  • 1,557 Answers
I would be of the oppinion you have suffered a power surge and most of the curcuits are fried in my oppinion you need to replace the unit if it can be proven it was a surge your power company by law must pay to replace it to do this you need a pro tech to certify it was a surge (power spike) or if you have home contents insurance its covered by them as well
sorry
good luck
Posted on May 15, 2010
TECNIK TDK 795 FAULT
is there the power supply still to the washer??
Mar 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
My Panasonic KXTGA520M handsets, abt 8y. old, both cut out w/in 10 mins or so with no warning, yet their LCDs show "fully charged" and the base unit still works fine if I use it on speaker function.
These batteries only good for about 500 charges before they start to lose stamina .time to go to eBay and buy replacement batteries.they are around £6 -£8 .
Dec 06, 2014 | Panasonic Lands Phones
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
I have a SE6TIE1, FD 8004 090109 Tecnik dishwasher and when i put my dishwasher on it only makes a little sound right at the beginning and then no sound and does not wash the dishes. I opened up the spray...
The water inlet valve, also called a solenoid fill valve, controls the flow of water into the dishwasher by opening and closing. If the water inlet valve doesn't open at all, water can't flow into the dishwasher.so it can not start the sequence.
Oct 25, 2017 | Tecnik Dishwashers
Tecnik dw2677/2 how do i reset dishwasher it won't empty just bleeps and light flashes 4 times
Unplug and let it sit for an hour. Replug and then try turning it on. If that doesn't work press and hold the power button and then unplug and retry. If that doesn't work press and hold the power and cycle buttons together to reset.
Aug 17, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
After the wash cycle the unit will not empty, according to the feedback on this page they sujest a dishwater cleaner, can you tell me what type and where to obtain it.
I don't know that a dishwater cleaner will solve your problem. More than likely the pump is no onger functioning which is located on the bottom of the unit. When the dishwasher goes into the discharge cycle does it make a humming sound or does it do nothing. All pumps make sound when discharging the water from the basin. If there is no sound present then the pump is not functioning........if the pump is making a humming sound then it is locked up. Let me know please thanks.
Deathstalker
Sep 01, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik Built In Dishwasher SE6TIE1GB/17
You can try reseting the machine buy holging down outside two cycle buttons for 3 seconds, then release. After a minute the end light should come on. Then use as normal. If this fails pull the unit out, then take of the side panels (screws to the front in the seal) & check the red anti-flood float on the left side of the machine, to make sure it is not up activating the cut out switch. This may be due to the machine leaking somewhere and the float raises and activates the switch, or as in my case a build up of limscale has raised it up enough to activate it.
Hope this helps
Mar 06, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
No water from top and bottom arm
I'm not familiar with that exact unit. However, all dishwashers use a solenoid valve and pump to either send the water to the drain or to the arms. If the water drains, the pump is good. Check the solenoid valve. It may be jammed (toothpicks and food particles are wonderful) or burned out. If the valve is good and working, your timer is a suspect.
Jun 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik tkd795/3 beeps every 10 minutes when done - please stop
I have just solved it by holding down the power on button and then pressing the Button 'c' fro the handbook which on some is the right hand of the reset button combination or the rinse only function. It starts to flash after a short while then goes through the different beeps -quiet, medium, loud and then yes at bleeding last!!! OFF
Peace for me
Oct 07, 2007 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
167 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
