Question about Proscan PS27108 TV
Hi. TV works with dvd player. We have coaxial cable connected directly from Comcast. When we want watch cable the picture is ok some of the time but much of the time the sound and picture quality gets worse until there is no picture or sound. Sometimes the picture and sound will come back after a few minutes. Sometimes if we tap or wack side of tv the picture and sound will come back. When this is occuring most of the time the quality of the picture and sound will vary on different channels. Almost no picture on one channel where another channel you have a picture and sound.
  • Travis Layman May 15, 2010
    Thanks for the help. We will give it a try.
  • Proscan Master
  • 19,396 Answers
Hi.
The problem is usually with Comcast connection. Pixelation and bad or freezing picure are caused by bad cable signal.
All you can do as user is replacing the coax cable from the wall box or splitter. If you use a Comcast receiver box, also replace the video cable from box to TV, and eventually test the box on a different video connection.
If that does not fix the problem you will need to contact Comcast, as the fault is usually with cable lines or box(when present), and definitively it is not caused by a fault on your TV.
Here contact page: Contact Comcast | Customer Service.
Regards.
Ginko.
Posted on May 15, 2010
    Thanks. I should have also added that the same coaxial cable plugged into another tv works perfectly. I read somewhere that the rf component can go bad and that you can route the cable through a vcr and it will work, but we don't have a vcr. Wondering if one of the dvd/vcr recorders would work because they have similar coaxial input and outputs like vcrs I think.
  • Ginko
    Ginko May 15, 2010
    Hi.
    The RF connector is part of tuner board on your TV.
    If the signal is delivered tot TV through a regular coax antenna cable, then you can use any VCR or DVD , then route connection to TV.In this case there will be a receiver in the middle.
    If the TV uses direct RF (coax cable) connection, like in your case, instead of using a VCR or a DVD, you will need to use a device with integrated cable tuner. In this case, rather than using a VCR, better using a Comcast cable receiver box.
    If your VCR has RF connection, you can use VCR connected to cable, then run component, AV or similar connection to TV.
    As said, a good thing to do is also contacting Comcast. They can also tell you conditions to get a receiver box or to upgrade to HDTV.
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
How do I hook up a dvd player recorder to my tv, so I can record? thank you DEE
Hi dbird30,
You will notice that your DVD player has two types of cables, one that is three cables in one with yellow, red and white colors; and other that is bigger and cylindrical, we call this a coaxial cable. To record from the TV you must unplugg the TV's cable and plugg it into your DVD player, plugg it where it says 'cable' or 'input'. Now you must connect the coaxial cable it came with your DVD player and plugg it into the DVD player where it says 'to TV' or 'output' and connect the other side of the coaxial cable to the TV. At the end you should see that the cable that was plugged into your TV is now plugged into your player, and the player is now connected through another coaxial cable to the TV.
Jul 12, 2008 | Televison & Video
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
64 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
