Question about Maytag Atlantis MAV9501E Top Load Washer
My cold water won't work. I can get hot water but
My cold water won't work. I can get hot water but not cold. Checked the hoses and the water valve.
  • 1,557 Answers
Replace the hot water valve!!!!!!!
Posted on May 15, 2010
  • 183 Answers
SOURCE: cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Posted on Aug 22, 2007
canbruce75
  • 1776 Answers
SOURCE: no cold water only hot water will filling
The water inlet valve solenoid is probably faulty. You can check it using a multimeter or ohm meter for continuity to see if it is faulty. The solenoid is most likely faulty on the cold water side. Here is a picture of the inlet valve solenoid assembly. Hope this helped and best wishes.
Posted on Jul 31, 2009
  • 106 Answers
SOURCE: Water changes from hot to cold. Valves checked out
Bad thermistor or bad board. Or its just a energy super saver and it will not let you use all that hot water. Did it work before or its been like this since new? New energy star models will only let it just get warm for hot wash, saving energy. warm wash is like 70 deg water.
Posted on Nov 21, 2009
  • 108 Answers
SOURCE: Maytag Neptune nf error
My guess is that something got disturbed in the plug when you pulled it off/put it back on. You turn it to "hot wash" and it does nothing? Does it buzz?
Posted on Jan 08, 2010
  • 13 Answers
SOURCE: GW52F Fisher and Paykel Washing Machine
you should check new washing machine..i know a effective site..
http://www.washingmachineadvisor.com/
Posted on Feb 02, 2010
My washing machine won't fill with water, water is going into the powder drawer but won't fill up the clothes barrel, I have checked the filter at the front and have done this many times so there...
Although you say that there is enough water for the dispenser it is well worth carrying out the following, especially because of the 'clicking' ;-0)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 18, 2011 | Washing Machines
Washer don't get the cold water only the hot cold water won't enter and the hot enter extremelly hot
(this covers both hot and cold but please read for cold! Your hot water supply provides the extremely hot water and is normally mixed with cold in the washer for the correct temperature.)
John C
Aug 27, 2011 | Frigidaire FWS833A Top Load Washer
The display will come on but it will not operate - timer works - display works - it just won't start
Just in case it is waiting for water to fill it try this-
John C
Aug 20, 2011 | Maytag Neptune MAH5500B Front Load Washer
Bosh classic 1200 won't fill with water,
John C
Jul 22, 2011 | Washing Machines
My washer won't fill water to wash or rinse
John C
Jul 13, 2011 | Washing Machines
My washing machine model mw512 will not fill properly on the cold cycle - it just dribbles. I have checked the hose which is fine and the hot works ok also.
this is a sign that the hot/cold mix valve is bad and not opening properly.
the valve is the small plastic part that both hoses go into on the back of the machine,, if you remove the two hoses and the back panel from the machine - the valve is held in place by one little screw. there are four wires that connect to the valve -- make sure you label the hot water wires and the cold water wires. your local appliance repair shop will have this part on hand and they will sell it to you for around 25 dollars.
c...
Jan 29, 2011 | Fisher and Paykel Fisher & Paykel Washer
The cold water fill just trickles, I removed filter it was not clogged, hot water runs fine. I checked water flow at faucet, I checked for kinked hose. Did not find any obvious problem. Is there a check...
Good day,
The washer has a dual valve, Hot and cold. The cold side has failed. Valve needs to be replaced. Very common problem.
Before changing, turn off cold water supply, remove cold water hose at the machines valve, and turn on to check for proper pressure.
Dec 04, 2009 | KitchenAid KAWS850L Top Load Washer
I can't get the cold water to fill the tub/rinse. the hot works.
Your problem is either a clogged COLD fill valve or a bad water fill valve. Turn the water off. Remove the COLD hose from the WASHER. Check the filter screen inside the valve for sediment. If you find sediment,remove the screen and clean it. Replace the screen and turn the water back on. If you do not find sediment on the screen,replace the water valve.
Sep 21, 2009 | Frigidaire FWS1339A Top Load Washer
We have pressure on the cold water side but not on the hot. The faucet in the bathroom sink has hot water pressure.
make sure your water valve is working properly undo line and open valve if its working than take apart faucet and check for debri
Jul 17, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Maytag Atlantis MAV9501E Top Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
