Question about EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Cant' find driver for motherboard driver ecs p4m800-8237
My sound doesn't work right, my USB port doesn't work right either
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Sound: http://eu.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1764&areaid=2&LanID=0
USB: http://eu.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2168&areaid=2&LanID=0
Posted on May 15, 2010
These guys have drivers for everything
www.driverstorer.com
Posted on Aug 05, 2010
Transcend 16 gb pendrive is not recognised
Right-click on COMPUTER. Select PROPERTIES, Go to DEVICE MANAGER. Under UNIVERSAL SERIAL BUS CONTROLLERS, check all the USB ports to see if they are working properly. If the USB PORT in which you have inserted your pen-drive, is showing an error, right-click over it and select PROPERTIES and make a TROUBLESHOOT.
If this troubleshooting doesn't help you, use another computer to check if your Pen-drive is working there. If the problem persists, go to the manufacturer's service center and ask for a replacement or repair.
Hope this helps, Mrityunjay.
Jun 25, 2012 | Electronics - Others
When i installed my radio its reading usb error
hit done? But first read through the manual and see if there is any sort of initiall startup procedure. (unlikely)
Then try checking all connections. If that doesn't work, unplug, check for the right connection ports, and replug everything. If it still doesn't work, take it to a professional or return it and buy a new one, it could just be defective.
May 01, 2012 | Kenwood DNX7100 Car Video Player
3rd USB Port doesn't work and "no audio output device is installed" in Vista 32-bit
The USB port is damaged, or missing the driver for that port, check device manager.
Mar 15, 2012 | Computers & Internet
Team promark keyboard won't work
If it has a USB plug, try attaching it through a different port hub, i.e. not the usb port right next to the one that didn't work. If that doesn't work, test the usb port with something else first. If the USB port is not the problem, you may need to download a driver for the keyboard.
Jan 03, 2012 | Team International Team ProMark Carolina...
Nexxtech external USB hard drive stopped working. Light comes on but drive does not seem to activate and produces no response in the laptop.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
a cnet rview
Pros: Lots of space, very low price, doesn't require outside power
Cons: Sometimes stops working, no firewire (but still a quick transfer speed)
Summary: This doesn't require outside power, but sometimes you need to hook it up to 2 USB ports. The USB cable has 2 heads. Sucks when I only have 3 USB ports on my laptop.
Also sometimes it spontaneously stops communicating with the computer. I don
Oct 04, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
I've just bought a second hand ASUS P4S800MX motherboard and the installation appeared to work just fine but when it booted up, all USB ports and the audio outlets are not working. Am using windows XP....
Here is the link, some of the text is in Danish, but just press the download tab, and all of the useful text is in english.http://www.asus.dk/Motherboards/Intel_Socket_478/P4S800MX/#downloadGlobal
If you already have tried this download, are you sure this isn't the se version of the motherboard?
Regarding the usb and sound; first of all have you installed al the drivers supplied with the motherboard? If you have, then have you connected the internal usb pins to the external ports and tried every usb port including those on the back?
Unfortunately that is what I can suggest at this point... If that doesn't work, and updating the bios doesn't work, then I suggest resetting the motherboard.
Hope this helps
Sep 20, 2011 | ASUS P4S800-MX Motherboard
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Why doesn't my Verbatim "clip
click start right click on computer select properties then device manager scroll to universal serial bus controllers if you se a yellow question exclamation mark ? ! or a red X you will need to update/reinstall drivers right click select update drivers
once inserted windows 7 should automatically install the drivers
if you computer came with a motherboard disk the drivers could be on it
if you can see your usb drive but its not working
if this fails to fix the problem check the usb leads inside your computer usually
usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Sep 06, 2011 | Verbatim VER95327 USB Hard Drive
Computer will not recognize mp3 player, device doesn't light up
The two most likely causes for this is either your USB port or the USB cable itself. Try plugging the device into different ports and if that doesn't work, get yourself a different USB cable. If neither of those works then your device is faulty and the only fix for that is to get it serviced by the manufacturer.
Jul 02, 2011 | Computers & Internet
My usb port wont reginize my usb stick
try putting your USB stick in the port provided at the back side your PC !!! if it doesn't work try in your friends PC if it doesn't work there then your USB stick must have failed!!
Jun 15, 2011 | Computers & Internet
EliteGroup P4M800PRO-M2 (V2.0) Motherboard Logo
1,215 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
